error message when I run a rule
mostafamahmoudseddek94
I have a rule called "Configurator" I run this rule many times before and it worked fine but not anymore and it responds today with an error message and I do not understand the message
can anyone tell me what happened here and what this message tell
you can find the code I have written below
I use Inventor 2019  and if there is additional info you need to help me, let me know
Thanks & best regards
'                                                     Stiffners
If Valve_NO < 11 Then
	Parameter("Inspectiondoor_reinf:1", "Height") = 30 mm
	Parameter("Inspectiondoor_reinf:1", "Thickness")= 4 mm
Else If Valve_NO >= 11 And Valve_NO <= 14 Then
	Parameter("Inspectiondoor_reinf:1", "Height") = 40 mm
	Parameter("Inspectiondoor_reinf:1", "Thickness")= 6 mm
' stiffners FD
If Bags_NO = 4 Then
		Stiffeners_FD = 250 mm
ElseIf Bags_NO = 5 Or Bags_NO = 7  Then
		Stiffeners_FD = 285 mm
ElseIf Bags_NO = 6 Then
		Stiffeners_FD = 185 mm
ElseIf Bags_NO = 9 Then
		Stiffeners_FD = 375 mm
Else
		Stiffeners_FD = 385 mm
' Stiffners Spacing
If     Bags_NO = 4  Then
	 Spacing = 250 mm
	Spacing = 340 mm
ElseIf Bags_NO = 11 Then
	Spacing = 350 mm
ElseIf Bags_NO = 13 Then
	Spacing = 360 mm
Else
	Spacing = 400 mm
' Stiffners NO
Stiffeners_NO = 1 + (Parameter("InspectionDoor_Cover:1", "Length") -2 * Stiffeners_FD - Parameter("InspectionDoor_Stiffeners:1", "Thickness")) / Spacing
'                                                     Hinge
'Hinge FD
If Bags_NO <= 7 Then
	Hinge_FD = 160+12 mm
Else
	Hinge_FD = 360+12 mm
'Hinge NO
If Bags_NO <= 11 Then
	Hinge_NO = 2
Else
	Hinge_NO = 3
' Hinge X
Hinge_Spacing =(((Parameter("InspectionDoor_Cover:1", "Length")+2*Parameter("InspectionDoor_Cover:1", "Thickness")) -2*(Hinge_FD-12)-120))/(Hinge_NO-1)
'                                                     Handles
 If Bags_NO = 4 Then
	HandleOffsite = -530 mm
	Handle_NO = 1
	Component.IsActive("InspectionDoor_Hand:2") = False
Else If Bags_NO = 5 Then
	Component.IsActive("Hand Pattern") = False
	HandleOffsite = -600 mm
	Handle_NO = 1
	Component.IsActive("InspectionDoor_Hand:2") = True
Else If Bags_NO = 6 Or Bags_NO = 7 Then
	HandleOffsite = -340 mm
	Handle_NO = 1
Else If Bags_NO = 8 Then
	HandleOffsite = -190 mm
	Handle_NO = 1
Else If Bags_NO > 8 And Bags_NO <= 11 Then
	Handle_NO = 2
Else If Bags_NO = 12 Then
	HandleOffsite = -155 mm
	Handle_NO = 3
Else If Bags_NO = 13 Then
	HandleOffsite = -165 mm
	Handle_NO = 3
Else If Bags_NO = 14 Then
	HandleOffsite = -175 mm
	Handle_NO = 3
ckeveryga
It's kind of difficult to troubleshoot without the whole code and the model, but it seems like the error occurs while setting a Parameter. Maybe try to fix this line by capitalizing the component name?
"InspectionDoor_reinf:1"
 If this doesn't work you can troubleshoot by inserting a message box into different sections of the code to find the exact line that is causing the issue.
