Error launching Inventor 2020 from scheduled task
cstaley
cstaley
I have a custom tool that runs on the Windows task scheduler and launches Inventor to perform processes on a set of models and drawings retrieved from Vault.  The tool work perfectly when launched manually, or even from Task Scheduler as long as a user is logged in.
Any time the task is triggered after I close my remote connection to the server (Windows 10), Inventor fails to launch with the following error...
Retrieving the COM class factory for component with CLSID {B6B5DC40-96E3-11D2-B774-0060B0F159EF} failed due to the following error: 80080005 Server execution failed (Exception from HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE))
This tool was running with Inventor 2019 before it was ported to 2020.  The settings of the scheduled task have remained as they were in the previous version.
adam.nagy
Autodesk Support
Autodesk Support
You say everything worked with Inventor 2019, but could you please double-check that the service is set to be UserInteractive?
See https://forums.autodesk.com/t5/inventor-customization/issue-with-autodesk-inventor-api/m-p/6068391
Adam Nagy
Autodesk Platform Services
