Error inventor2014 on window 10
Message 1 of 1
I read the this word,
Autodesk 2013–2015 Products
Further testing of Autodesk 2013–2015 products is required to determine compatibility with Windows 10 and should be considered unsupported on Windows 10 unless explicitly stated otherwise in the details that follow or in the system requirements for that product and version. Please note the following product-specific details:
  • The 2013–2014 versions of AutoCAD and AutoCAD-based verticals will not be supported on Windows 10.
  • The English language versions of AutoCAD 2015 and AutoCAD-based verticals should be installable if you have received the Windows 10 update, KB3081448 or later.
  • Other AutoCAD language versions and language packs can be installed if Windows 10 update, KB3105210, is applied prior to installation.
  • DWG TrueView 2015 can be installed if Windows 10 update, KB3105210, is applied prior to installation.
Note: This article will be updated as new Windows 10 compatibility information becomes available
Now, I installed Inventor2014. but I cannot operation.
If I understand correctly, I cannot inventor2014. So I have to installation NEW Version(inventor2016 or 2017), right?
I wonder How can I install.
Replies (0)
