I am new to ilogic.
trying to read a value out of an excel workbook that is embedded in my IPT file.
I keep getting
hk_row = 9' deleted parameter 'width_row = 3' deleted parameter If thk >= 20 Then thk_row = "13" ElseIf thk >= 17 Then thk_row = "13" ElseIf thk >= 16 Then thk_row = "13" ElseIf thk >= 15 Then thk_row = "13" ElseIf thk >= 14 Then thk_row = "12" ElseIf thk >= 13 Then thk_row = "12" ElseIf thk >= 12 Then thk_row = "12" ElseIf thk >= 10 Then thk_row = "11" ElseIf thk >= 9 Then thk_row = "10" ElseIf thk >= 8 Then thk_row = "9" ElseIf thk >= 7 Then thk_row = "8" ElseIf thk >= 6 Then thk_row = "7" ElseIf thk >= 5 Then thk_row = "6" ElseIf thk >= 4 Then thk_row = "5" ElseIf thk >= 3 Then thk_row = "4" ElseIf thk >= 2 Then width_row = "3" ElseIf thk >= 1 Then thk_row = "2" ElseIf thk > 0 Then thk_row = "1" End If 'thk_column = 1' deleted parameter 'width_column = 8' deleted parameter If width >= 20 Then thk_column = "N" ElseIf width >= 17 Then thk_column = "N" ElseIf width >= 16 Then thk_column = "N" ElseIf width >= 15 Then thk_column = "N" ElseIf width >= 12 Then thk_column = "M" ElseIf width >= 10 Then thk_column = "L" ElseIf width >= 9 Then thk_column = "K" ElseIf width >= 8 Then thk_column = "J" ElseIf width >= 7 Then thk_column = "I" ElseIf width >= 6 Then thk_column = "H" ElseIf width >= 5 Then thk_column = "G" ElseIf width >= 4 Then thk_column = "F" ElseIf width >= 3 Then thk_column = "E" ElseIf width >= 2 Then thk_column = "D" ElseIf width >= 1 Then thk_column = "C" ElseIf width > 0 Then thk_column = "B" End If If lg >= 20 Then thk_chart = "Sheet39" ElseIf lg >= 17 Then thk_chart = "Sheet39" ElseIf lg >= 16 Then thk_chart = "Sheet39" ElseIf lg >= 15 Then thk_chart = "Sheet39" ElseIf lg >= 14 Then thk_chart = "Sheet25" ElseIf lg >= 12 Then thk_chart = "Sheet25" ElseIf lg >= 10 Then thk_chart = "Sheet24" ElseIf lg >= 9 Then thk_chart = "Sheet23" ElseIf lg >= 8 Then thk_chart = "Sheet22" ElseIf lg >= 7 Then thk_chart = "Sheet21" ElseIf lg >= 6 Then thk_chart = "Sheet20" ElseIf lg >= 5 Then thk_chart = "Sheet19" ElseIf lg >= 4 Then thk_chart = "Sheet18" ElseIf lg >= 3 Then thk_chart = "Sheet17" ElseIf lg >= 2 Then thk_chart = "Sheet16" ElseIf lg >= 1 Then thk_chart = "Sheet15" ElseIf lg > 0 Then thk_chart = "Sheet14" End If oPath = "\\filesrv\USERS\ENGINEERING\Inventor\" '("\\filesrv\Engineering\Inventor\Inventor\INVENTOR_MASTERS\rect_stk_chart.xlsx", "Sheet1", "help", "=", 1) oFileName = "thk_stk_rect.xlsx" colm = Parameter("thk_column") oPN = Parameter("thk_row") sht = Parameter("thk_chart") 'get row using part number oRow = GoExcel.FindRow(oPath & oFileName, sht,"ht", "=", oPN) Parameter("stk_thk") = GoExcel.CellValue("3rd Party:thk_stk_rect.xlsx", sht, colm & oPN ) 'get value in 2nd column 'Parameter("ID") = GoExcel.CellValue(oPath & oFileName, "Sheet1", "C" & oRow) 'get value in 3rd column 'Parameter("LG") = GoExcel.CellValue(oPath & oFileName, "Sheet1", "D" & oRow ) 'get value in 4th column InventorVb.DocumentUpdate()
errors that a cannot figure out.
Error in rule: look_thk_combine, in document: rect_new.ipt
GoExcel: Could not match the column title: "ht"
System.ArgumentException: GoExcel: Could not match the column title: "ht"
at iLogic.GoExcel.FindColumn(String columnName)
at iLogic.GoExcel.FindRow(String fileName, String sheetName, Object[] sizeArgs)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
