Error during access Camera into DrawingView
Hi!
I try to get camera object for selected drawing view. I use vba macro for this (below) and in string "set oCam = oView.Camera" i get Run-time error 445 Object doesnot support this action. How to solve this situation?
Dim oSelectSet As SelectSet
Set oSelectSet = ThisApplication.ActiveDocument.SelectSet
' Check to make sure a single item was selected.
If oSelectSet.Count = 1 Then
' Check to make sure a face was selected.
If TypeOf oSelectSet.Item(1) Is DrawingView Then
' Set a reference to the selected face.
Dim oView As DrawingView
Set oView = oSelectSet.Item(1)
MsgBox oView.Name
Dim oCam As Camera
Else
MsgBox "You must select a single drawing view."
Exit Sub
The code seems fine, what type of view do you have selected? Does it fail
with any other view types?
Neil
wrote in message news:5730778@discussion.autodesk.com...
Hi!
MsgBox oView.Name
Dim oCam As Camera
Else
Exit Sub
Very interesting, but i get same error on all views. I tested macro in AIP 11 SP3. I don't know what to do?
That is indeed the problem, it is supported in 2008 API, not in R11. Sorry.
Neil
wrote in message news:5730762@discussion.autodesk.com...
Thanks, Neil.
