Error Deleting Workplanes
jianchen.yu
jianchen.yu
I'm having some issues with the code below, it doesn't allow me to delete the workplanes before creating new ones, and it only fails in certain circumstances which doesn't seem relevant at all. The error is on the code "oWPlane.Delete". Please help.
Error on line 14 in rule: Work Plane Creation (indi.), in document: assembly.iam
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Sub Main
	oDef = ThisDoc.Document.ComponentDefinition
	Dim oWPlane As WorkPlane
	oSurfaces = oDef.WorkPlanes
	Dim name As String
	For Each oWPlane In oSurfaces
		 name = oWPlane.Name
		If Left(name, 3) = "dim"
          	    oWPlane.Delete
	Next
	myDoubleValues = New Double() {x1, y1, x2, y2, x3, y3, x4, y4, x5, y5, x6, y6, x7, y7, x8, y8, x9, y9, x10, y10, x11, y11, x12, y12 }
	Dim arrayAnchorX(anchorBoltNo - 1) As Double
	Dim arrayAnchorY(anchorBoltNo - 1) As Double
	For i = 0 To anchorBoltNo - 1
		arrayAnchorX(i) = myDoubleValues(i * 2)
		arrayAnchorY(i) = myDoubleValues(i * 2 + 1)
	Next
	Dim arrayAnchorUniqueX(0) As Double
	Dim arrayAnchorUniqueY(0) As Double
	arrayAnchorUniqueX(0) = arrayAnchorX(0)
	arrayAnchorUniqueY(0) = arrayAnchorY(0)
	'Delete all the duplicate dimension
	For i = 1 To anchorBoltNo - 1
		If Not arrayAnchorUniqueX.Contains(arrayAnchorX(i)) Then
			Array.Resize(arrayAnchorUniqueX, arrayAnchorUniqueX.Length + 1)
			arrayAnchorUniqueX(arrayAnchorUniqueX.Length - 1) = arrayAnchorX(i)
		If Not arrayAnchorUniqueY.Contains(arrayAnchorY(i)) Then
			Array.Resize(arrayAnchorUniqueY, arrayAnchorUniqueY.Length + 1)
			arrayAnchorUniqueY(arrayAnchorUniqueY.Length - 1) = arrayAnchorY(i)
	Next
	Array.Sort(arrayAnchorUniqueX)
	Array.Sort(arrayAnchorUniqueY)
	anchorDimQtyX = arrayAnchorUniqueX.Length
	anchorDimQtyY = arrayAnchorUniqueY.Length
	For i = 0 To arrayAnchorUniqueY.Length - 1
		oWPlane = AddWorkPlaneInAssemblyOffset(oDef.WorkPlanes("XY Plane"), -arrayAnchorUniqueY(i))
		oWPlane.Name = "dimPlaneXY" & i
		'oWPlane.Visible = False
	Next
	For i = 0 To arrayAnchorUniqueX.Length - 1
		oWPlane = AddWorkPlaneInAssemblyOffset(oDef.WorkPlanes("YZ Plane"), arrayAnchorUniqueX(i))
		oWPlane.Name = "dimPlaneYZ" & i
		'oWplane.Visible = False
	Next
End Sub
Function AddWorkPlaneInAssemblyOffset(oFace As Object, oOffset As Double) As WorkPlane
	Dim uOM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
	Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
	Dim oOriginPnt As Point
	Dim oXaxis As UnitVector
	Dim oYaxis As UnitVector
	oOriginPnt = ThisApplication.TransientGeometry.CreatePoint(0#, 0#, 0#)
	oXaxis = ThisApplication.TransientGeometry.CreateUnitVector(1#, 0#, 0#)
	oYaxis = ThisApplication.TransientGeometry.CreateUnitVector(0#, 1#, 0#)
	Dim oPlane As WorkPlane = oDef.WorkPlanes.AddFixed(oOriginPnt, oXaxis, oYaxis)
	oPlane.AutoResize = True
	oDef.Constraints.AddFlushConstraint(oFace, oPlane, uOM.ConvertUnits(oOffset, uOM.LengthUnits, UnitsTypeEnum.kDatabaseLengthUnits))
	oPlane.AutoResize = False
	Return oPlane
End Function
WCrihfield
Hi @jianchen.yu.  Is it possible that any of those WorkPlanes that you are trying to delete may have dependents?  If the WorkPlane has a sketch on it, is being used by a feature, or any other WorkPlane is based off of the WorkPlane, it has dependents, and will not delete correctly, unless maybe you specify the optional input Boolean as True in that Delete method.
Wesley Crihfield
(Not an Autodesk Employee)
jianchen.yu
Thanks @WCrihfield, I've checked and there're no dependents on those workplanes I want to delete and I also tried oWPlane.Delete(True) and it still didn't work. Any other things I can try or is there another approach to this?
Thank you!
JMGunnar
@jianchen.yu
ilogic code work find on my computer
can you upload empty assemblies that's not working
Johan
jianchen.yu
@Anonymous, I fixed it. Turned out that if I delete all the constraints associated with those planes, the oWPlane.Delete will work.
JC
