Enabling Parts and Subassemblies in One Operation
mateusz_baczewski
mateusz_baczewski
Is there a way to enable all the parts and subassemblies in within a single operation? Right now, I'm creating a list of parts and subassemblies to enable and disable, then iterating through these elements to turn them on or off accordingly:
Logger.Info("_______Unsuppress_________")
For Each element As ComponentOccurrence In objectToUnsuppress
	Logger.Info(element.Name)
	element.Unsuppress
Next
Logger.Info("_______Suppress_________")
For Each element As ComponentOccurrence In objectToSuppress
	element.Suppress
Next
Additionally, I want to enable/disable elements at different levels, meaning both in the main
assembly and within subassemblies. In another project, I'm using:
If(oSelectSet.Count>0)
	ThisApplication.CommandManager.ControlDefinitions("AssemblyCompSuppressionCtxCmd").Execute2(True)
	oSelectSet.Clear
However, all the elements I enable or disable are in the main assembly, which works fine. But if the parts are at different levels, it no longer works.
Do you know of a way to accomplish this in a single operation? I want to do this because it significantly speeds up rule execution.
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
C_Haines_ENG
This is a very basic script, but it should put you on the right path. The trick is to access the components in the context of their respective assemblies. This will suppress everything in the document by the way.
Dim oAsm As AssemblyDocument = ThisDoc.Document
For Each oComp As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences
	Dim DocType As DocumentTypeEnum = oComp.Definition.Document.DocumentType
	If DocType = kPartDocumentObject
		oComp.Suppress
	ElseIf DocType = kAssemblyDocumentObject
		Dim oSubAsm As AssemblyDocument = oComp.Definition.Document
		For Each oSubComp As ComponentOccurrence In oSubAsm.ComponentDefinition.Occurrences
			oSubComp.Suppress
		Next
Next
