Enable Structured BOM through using VBA
Inventor_Enjoyer
Inventor_Enjoyer
Hey, I'm currently trying to enable structured bom (see picture) for all subassemblies inside main assembly
However I don't seem to get deep enough to subassembly level. I can enable or disable on main assembly level.
Any idea how to look into this better?
WCrihfield
Hi @Inventor_Enjoyer.  I assume you mean for the code to only effect the top level sub assemblies, and not any sub assemblies that are deeper than that, is this correct?  If so, then I have some iLogic code below that I think may work for you.
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
	Exit Sub
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oOccs As ComponentOccurrences = oADef.Occurrences
For Each oOcc As ComponentOccurrence In oOccs
	If oOcc.Suppressed Then Continue For
	If TypeOf oOcc.Definition Is VirtualComponentDefinition Then Continue For
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		Dim oSubADef As AssemblyComponentDefinition = oOcc.Definition
		Dim oSubAsmBOM As BOM = oSubADef.BOM
		If Not oSubAsmBOM.StructuredViewEnabled Then
			oSubAsmBOM.StructuredViewEnabled = True
Next
If oADoc.RequiresUpdate Then oADoc.Update2(True)
If oADoc.Dirty Then oADoc.Save2
But if you need it to effect all sub-assemblies in every level of the assembly, then this code may need to be changed a bit.  It wouldn't be that difficult to do though.  Instead of iterating through components, we could iterate through 'AllReferencedDocuments' to do that.
Wesley Crihfield
(Not an Autodesk Employee)
Inventor_Enjoyer
Hi @WCrihfield. Actually I think it needs to effect in every level, because some subassemblies may contain older assemblies which have it disabled
WCrihfield
OK, sure.  Here is an example of an iLogic rule for that scenario you can try out.
Dim oDoc As Document = ThisDoc.Document
Dim oRefDocs As DocumentsEnumerator = oDoc.AllReferencedDocuments
For Each oRefDoc As Document In oRefDocs
	'if it is not an assembly, skip to next referenced document
	If oRefDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Continue For
	Dim oSubADoc As AssemblyDocument = oRefDoc
	Dim oSubADef As AssemblyComponentDefinition = oSubADoc.ComponentDefinition
Next 'oRefDoc
If oDoc.RequiresUpdate Then oDoc.Update2(True)
If oDoc.Dirty Then oDoc.Save2
Wesley Crihfield
WCrihfield
Oops...I forgot you wanted the solution in VBA, not in iLogic, so here is the VBA version of that last code I posted.  Sorry about that.
Sub SubAsmStrBOMViewEnable()
    Set oDoc = ThisDoc.Document
    Set oRefDocs = oDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    For Each oRefDoc In oRefDocs
        If oRefDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then GoTo ContinueToNext
        Set oSubADoc = oRefDoc
        Set oSubADef = oSubADoc.ComponentDefinition
        Set oSubAsmBOM = oSubADef.BOM
ContinueToNext:
    Next 'oRefDoc
    If oDoc.RequiresUpdate Then oDoc.Update2 (True)
End Sub
Wesley Crihfield
