Enable/Disable part through Ilogic
mslosar
Advisor Advisor
mslosar
Apparently the occurrences tab setting aren't easily accessible through the code snippets in ilogic.
How would one go about writing a rule that, in essense, would say:
If x = "whatever" then
occurrence.enabled = false
else
occurrence.enabled = true
end if
I've been reading that LOD's and suppression aren't the best course of action for assemblies especially when you're dealing with 20-40 parts as I am. I've got an assembly and parts controlled by a spreadsheet and when things are clicked off in the spreadsheet they need to be off in the model/drawings/bills etc. I have it working (to an extent) with suppression of parts in the assembly, but that casues LOD errors in the drawings. Research says parts are best disabled which is what i'm trying to do.
mslosar
I think i've found it:
doc = ThisDoc.Document
compo= Component.InventorComponent("Part:1")
compo.Enabled= false
compo.Visible= false
At this point i'm not sure what the point of enabled is when used vs suppression. Well, other than you don't have to deal with LOD issues on drawing sheets.
Suppression via ilogic:
Makes part invisible
Removes from bill
Removes from weight calcs
Enabled(Disabled):
Leaves part on screen at about 80% transparent
Still lists in bill
Still calculates it's weight in the assembly.
MCADAEPFW
I am not sure if this has been answer but what I do if I want a part to be hidden and not part of the the BOM I use:
	Component.Visible("ComponentName") = False 'Invisible
	Component.InventorComponent("ComponentName").BOMStructure = BOMStructureEnum.kReferenceBOMStructure
 and then if I need it back I use:
	Component.Visible("ComponentName") = True 'Visible
	Component.InventorComponent("ComponentName").BOMStructure = BOMStructureEnum.kDefaultBOMStructure
Found this is the best way to create an iLogic assembly and not have to use LOD.
dutt.thakar
The best way I would deal with this issue is to use Visibility and Invisibility of the components that are needed in specific configurations. LOD's and suppressing components are not meant for this purpose they are used to reduce the amount of details in Large assemblies and unload them from your memory to increase the performance. even when you suppress the component, it does not go away from Bill of Materials.
You can use as, @MCADAEPFW  has mentioned, Component.Visible("Component Name") = True/False snippet to hide or unhide the components in your assembly the best way I found is, just use the above snippet as per your logic so for an example,
If x = "true"
Component.Visible("Bracket-1") = True
Component.Visible("Bracket-2") = False
Else if x = "False"
Component.Visible("Bracket-1") = False
Component.Visible("Bracket-2") = True
To change the BOM properties of visible and invisible components automatically rather than writing line for each component to change the BOM Structure, use below code which will run after you are done with visibility and invisibility stuff. I really find this handy as it automatically check whether your component is visible or not in the assembly and then automatically change its BOM properties. Imagine if you have 50 components that you are changing in each configuration and writing 50 lines to change BOM structure of each component
Dim oDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
For Each oOcc As ComponentOccurrence In oDef.Occurrences
	If oOcc.Visible = True Then
		oOcc.BOMStructure = BOMStructureEnum.kDefaultBOMStructure
	Else
		oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
Next
I hope this helps, If this has answered your question, please accept this as solution.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
