Embedding Inventor 2019 View into intranet
kolr.dani
kolr.dani
Hi Everyone!
I want to embedd inventor view into my intranet, that relies on html, php and css. I found that it's possible with Inventor View 2019. I found a sample code on :
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
But it doesn't work for me. What am i doing wrong? Or i missed something? I have an Inventor Professional 2019 Installed with SDK.
Please help!
YuhanZhang
Hi there,
I also noticed that the code in the page to demonstrate how to view Inventor data in webpage using Inventor View does not work anymore. This is because the ActiveX control InvenotrViewCtrl.ocx in the Inventor View had been updated to registry-free mode, and so the "classid" is not available from registry anymore. I will delete the page so it won't mislead users. I am not sure how would you like to use an online viewer, there is an online Autodesk Viewer which can help you I think, you can access it with below link, you can submit your data and view them in the viewer:
https://viewer.autodesk.com
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
kolr.dani
Hi!
Thanks for the input! I want to show the parts and assemblies on web platform , and then we want to integrate it into our company's intranet. I think i look for something open source solution that relies on javascript, if i found something i will share it in this conversation.
Thanks!
