Hello all,
I am trying to create an iLogic rule that access to every part within an assembly, look for a specific sketch, where a text box is created, and replace the text in it with the standard Part Number iProperty.
I tried using AI help and it managed to do by access to the Part Number iProperty value and copying it into the text box as a text (like manually written).
Private Sub Main()
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
' Loop through all components in the assembly
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oDoc.ComponentDefinition.Occurrences
SearchForSketch(oOccurrence)
Next
' Ensure updates happen after all modifications
iLogicVb.UpdateWhenDone = True
End Sub
Private Sub SearchForSketch(ByVal oOccurrence As ComponentOccurrence)
If TypeOf oOccurrence.Definition Is PartComponentDefinition Then
Dim oPartDoc As PartDocument
oPartDoc = oOccurrence.Definition.Document
' Ensure the document is open
If oPartDoc Is Nothing Then Exit Sub
' Loop through sketches to find "Part_Number"
Dim oSketch As PlanarSketch
For Each oSketch In oPartDoc.ComponentDefinition.Sketches
If oSketch.Name = "Part_Number" Then
Dim oTextBox As TextBox
For Each oTextBox In oSketch.TextBoxes
' Access the custom property "Part Number" using PropertySets
Dim oProperty As [Property]
oProperty = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number")
' Link the text box to the custom "Part Number" property
oTextBox.Text = oProperty.Value
Next
Next
ElseIf TypeOf oOccurrence.Definition Is AssemblyComponentDefinition Then
' If it's an assembly, iterate through subcomponents
Dim oSubOccurrence As ComponentOccurrence
For Each oSubOccurrence In oOccurrence.Definition.Occurrences
SearchForSketch(oSubOccurrence)
Next
End Sub
I was wondering if there is some way to, instead of insert text, insert the actual link of the iProperty, like it can be done when editing the text manually.
