Edit Sketch, Delete Constraints
shastu
Advisor Advisor
Message 1 of 18
shastu
When editing a Sketch, if you right mouse click on the sketch you are editing, there is an option called Delete Constraints.  Is this supported in the API for using VBA?  See attachment.
Replies (17)
Message 2 of 18
JelteDeJong
Some how i dont have this option but therefor i dont know if DimensionConstraint and/or  GeometricConstraint. Any wy here a rule that deletes both when you select a sketch.
Dim Sketch As PlanarSketch = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities,
                                "Select a sketch")
For Each Constraint As DimensionConstraint In Sketch.DimensionConstraints
    Constraint.Delete()
Next
For Each Constraint As GeometricConstraint In Sketch.GeometricConstraints
    If (Constraint.Deletable) Then
        Constraint.Delete()
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 18
shastu
Are you sure that you had the sketch active?  You have to edit the sketch and then Right Mouse Click on it.  Anyway, your code is not in VBA which is what I asked for.  Can you help me do the same thing in VBA?  I might be able to figure it out myself, but you would probably be faster.
Message 4 of 18
WCrihfield
This iLogic code lets you select individual sketch entities to delete its constraints, then loops for your next selection untill you click No.
Repeat :
Dim oSC As SketchEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "Select a Sketch Curve.") oConsts = oSC.Constraints For Each oGC As GeometricConstraint In oConsts oGC.Delete Next For Each oDC As DimensionConstraint In oConsts oDC.Delete Next oAns = MessageBox.Show("Keep going?","LOOP",MessageBoxButtons.YesNo,MessageBoxIcon.Question,MessageBoxDefaultButton.Button1) If oAns = vbYes Then GoTo Repeat Else Return End If
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 18
shastu
Thanks, but I need the code to be VBA.
Message 6 of 18
JelteDeJong
try this:
Public Sub deleteConstraint()
    Set Sketch = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select a sketch")
    Dim Constraint As GeometricConstraint
    For Each Constraint In Sketch.GeometricConstraints
            If (Constraint.Type <> ObjectTypeEnum.kCoincidentConstraintObject) Then
                Constraint.delete
    Next
End Sub
Jelte de Jong
Message 7 of 18
shastu
I am not sure why, but after I select the sketch, it never enters the If statements.  So it goes directly from the For Each line to the End Sub.
Message 8 of 18
shastu
I do know why.  When I did a sketch.GeometricConstraints.Count it returned a value of 0.  Also, I don't think the Delete Constraints from the sketch has anything to do with geometric constraints.
Message 9 of 18
JelteDeJong
very strange for me this works. Can u send some screeen shots of what you are doing. (Or part file if you are working with inventor 2018 or earlyer)
Jelte de Jong
Message 10 of 18
shastu
This is indeed strange.  My files are already in 2019 so I created a brand new file in 2018 and tried the code on just a basic square rectangular part with one sketch and one extrusion and it worked fine.  So then I tried to reproduce the same scenario as what I had in 2019 and then the code doesn't work but if I do the command in Inventor it still does work.  I don't know yet exactly what the problem is but it could have something to do with the fact that it involves a derived part.  I wouldn't think so, but that is the one obvious difference.  I have included both files for you to investigate.  If you open the 2018BC.ipt and run the code and then select Sketch2 under Hole1 then the code never enters inside the For Each loop.
Message 11 of 18
Curtis_Waguespack
Hi @shastu
This worked to delete the constraints on the file called 2018DC.ipt.
I hope this helps.
Curtis
Sub Main()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim oHole As HoleFeature
    Dim oSketch As Sketch
    For Each oHole In oCompDef.Features.HoleFeatures
        If Not oHole.Sketch Is Nothing Then
            Set oSketch = oCompDef.Sketches.Item(oHole.Sketch.Name)
            oSketch.Edit
        Dim oConstraint As DimensionConstraint
        For Each oConstraint In oSketch.DimensionConstraints
            oConstraint.Delete
        Next
        Dim oGeometricConstraint As GeometricConstraint
        For Each oGeometricConstraint In oSketch.GeometricConstraints
            If oGeometricConstraint.Deletable Then
                oGeometricConstraint.Delete
        Next
        oDoc.Update
    Next
End Sub
Message 12 of 18
shastu
I don't want to delete the DimensionConstraints and when I comment out that section I still do not get the same results as if I actually do the command in Inventor.  I still have "pink" lines.
Message 13 of 18
Curtis_Waguespack
Hi @shastu ,
Okay, give this one a try, I think this is Delete Constraints context command you mentioned in the first post.
I hope this helps.
Curtis
Sub Main()
            Dim oSelSet As SelectSet
            Set oSelSet = oDoc.SelectSet
            oSketch.Edit
            Call oSelSet.Select(oSketch)
            ' Get the CommandManager object.
            Dim oCommandMgr As CommandManager
            Set oCommandMgr = ThisApplication.CommandManager
            ' Get control definition for the line command.
            Dim oControlDef As ControlDefinition
            Set oControlDef = oCommandMgr.ControlDefinitions.Item( _
                                                         "SketchDeleteConstraintsCtxCmd")
            ' Execute the command.
            Call oControlDef.Execute
        oDoc.Update
    Next
End Sub
Message 14 of 18
shastu
Thank you so much.  How did you find it?
Message 15 of 18
Curtis_Waguespack
I ran this (from the iLogic editor) and then searched for "DeleteConstraint" in the resulting text file... the key part to using it though is that we have to select the sketch first (since this one is a context command) .
' Get the collection of control definitions.
Dim oControlDefs As ControlDefinitions
oControlDefs = oCommandMgr.ControlDefinitions
'____Create and write to a text file_________________
oFile = "C:\temp\CommandNames.txt"
oWrite = System.IO.File.CreateText("C:\temp\CommandNames.txt")
oWrite.WriteLine(vbTab & "Command Name" &  vbTab &  " | " & "Description")
' Iterate through the controls and write out the name.
For Each oControlDef In oControlDefs
	oWrite.WriteLine(oControlDef.InternalName  & vbTab & " | " & oControlDef.DescriptionText )
Next
oWrite.Close()
'open the file
ThisDoc.Launch(oFile)
Message 16 of 18
JelteDeJong
i think i found the problem. In my original post i only tested with a square that i had drawn but in your example you have a square that is a refrence to a model geometry.  It seem that the command "delete all constraints" also deletes the refrences to the model geometry. When i incorporate that in the code it seems to work. Try this code.
    Dim line As SketchLine
    For Each line In Sketch.SketchLines
        line.Reference = False
    Next
                Constraint.Delete
    Next
End Sub
 Edit:
i see now that @Curtis_Waguespack has found a other solution.
Jelte de Jong
Message 17 of 18
shastu
That is even BETTER!!!  I really didn't want to delete all geometric constraints but just the reference lines so this is great.  Thanks again.
Message 18 of 18
Jayportland
I know its been a while since this was asked but I just stumbled upon this thread while searching for a way to automate the deletion of coincident constraints.
The image that the original poster attached is standard functionality of Inventor.  The option in the right-click menu is a default when you have a sketch active, the caveat is that you must already have a Geometric Constraint (other than coincident) already existing in the sketch.
