Edit feature possible? (VB6)
I'm working with a "function" to edit Part Features within Assembly
documents.
Equal to: Select "Feature Priority" - Right click on selected Feature and
"Edit Feature" (and also "Edit Sketch" if possible)
Is it possible through API?
Lars
Sure,
Looks like you have some reading to do. 🙂
In Inventor from the main menu:
Help / Programming Help
You will want to start with the:
Sketches overview
Features overview
Assembling parts overview
I am assuming you want more than to just launch the editing modes.
~Tom
Tom (and all other)
I have used parts of the samples and tested following code with "some
success".
' Create a new clsSelect object.
Dim oSelect As New clsSelect
' Call the pick method of the clsSelect object and set
' the filter to pick any feature.
Dim oFeature As PartFeature
Set oFeature = oSelect.Pick(kPartFeatureFilter, "Select Feature to
edit")
MsgBox "Feature name is: " & oFeature.Name
My problem now is if it's possible to just edit the selected feature. (like
the context menu, "Edit Feature")
Lars
skrev i meddelandet news:5268909@discussion.autodesk.com...
Sure,
Sketches overview
Features overview
~Tom
