edit BOM.SetPartNumberMergeSettings on other assembly
jaimievandamme1
jaimievandamme1
Hello everyone,
i would like a way to make a copy of my assem via ilogic and then change the .BOM.SetPartNumberMergeSettings(false) in that copy and save it back. the change must be made in the copy and not in the assem by turning this parameter off before saving and turning him back on after saving.
i have the save part already.
tnx,
Try
iLogicVb.RunRule("update view rep drawing")
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
Dim FName As String = oDoc.FullFileName
Dim FNP As Integer = InStrRev(FName, "\", -1)
Dim oPath As String = Left(FName, FNP)
'Dim oNewName As String = InputBox("Enter New File Name", "Save as", "Name")
Dim oNewName As String = "samenstelling_voor_partslist"
' If the user closes the input box, then stop the function
If oNewName = vbNullString Then Exit Sub
Dim oType As String
Select Case oDoc.DocumentType
Case kPartDocumentObject:     oType = ".ipt"
Case kAssemblyDocumentObject: oType = ".iam"
Case kDrawingDocumentObject:  oType = ".idw"
End Select
oDoc.SaveAs(oPath & oNewName & oType, True)
iLogicVb.UpdateWhenDone = True
Catch
end try
JhoelForshav
Just adding to your code without really testing it myself. Are you looking for something like this?
Try
Dim oType As String
End Select
'Open the copied document hidden
Dim NewDoc As AssemblyDocument = ThisApplication.Documents.Open(oPath & oNewName & oType, False)
'Set PartNumberMergeSettings
NewDoc.ComponentDefinition.BOM.SetPartNumberMergeSettings(False)
'Save the document
NewDoc.Save()
'Close the document
NewDoc.Close
Catch
End Try
jaimievandamme1
works like a charm.
thank you verry mutch.
jaimievandamme1
i want to renummber the BOM. i have try:
NewDoc.ComponentDefinition.BOM.RenumberItemsSequentially(True)
after the
but it do not work. do you have any idea?
tnx
JhoelForshav
Hi @jaimievandamme1
You can renumber the BOM views "Structured" and "Parts Only". I dont know which one you want to renumber but I added code to renumber both. The arguments In the method BOMView.Renumber are startvalue and increment value.
Try
Dim oType As String
End Select
'Set a parameter for holding BOM object
Dim newDocBOM As BOM = NewDoc.ComponentDefinition.BOM
newDocBOM.SetPartNumberMergeSettings(False)
'----Renumber Structured View--------
newDocBOM.StructuredViewEnabled = True
newDocBOM.BOMViews(2).Renumber(1, 1)
'----Renumber Parts Only View--------
newDocBOM.PartsOnlyViewEnabled = True
newDocBOM.BOMViews(3).Renumber(1, 1)
'Save the document
NewDoc.Save()
'Close the document
NewDoc.Close
Catch
End Try
