Edit an existing Extrude feature
Raider_71
Raider_71
Hi, I am trying to modify an existing Extrude feature using the API but keep getting an error saying Parameter is incorrect. I would like to change the Extrusion to be ToNext instead of a distance extrude. Please see the sample part attached.
My code:
    Private Sub BtnModifyExtrusion_Click(sender As Object, e As EventArgs) Handles BtnModifyExtrusion.Click
        Dim oDoc As PartDocument = oApp.ActiveDocument
        Dim oCompdef As PartComponentDefinition = oDoc.ComponentDefinition
        Dim oExtrude As ExtrudeFeature = oCompdef.Features.ExtrudeFeatures.Item("Extrusion1")
        Dim oExtrudeDef As ExtrudeDefinition = oExtrude.Definition
        Dim oSurfBody As SurfaceBody = oCompdef.WorkSurfaces.Item("TerminationSurf2").SurfaceBodies.Item(1)
        oExtrudeDef.SetToNextExtent(PartFeatureExtentDirectionEnum.kPositiveExtentDirection, oCompdef.WorkSurfaces.Item("TerminationSurf2").SurfaceBodies.Item(1))
    End Sub
Any advice would be appreciated.
Cheers
aelqabbany
This is a bit "hacky", but it works:
		Dim oExtrudeProfile As Profile = oExtrudeDef.Profile
		Dim oExtrude2Def As ExtrudeDefinition = oCompdef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oExtrudeProfile,PartFeatureOperationEnum.kNewBodyOperation)
		oExtrude2Def.SetToNextExtent(PartFeatureExtentDirectionEnum.kPositiveExtentDirection, oSurfBody)
		Dim oExtrude2 As ExtrudeFeature = oCompdef.Features.ExtrudeFeatures.Add(oExtrude2Def)
		oExtrude.Delete(True)
		oExtrude2.Name = "Extrusion1"
    End Sub
Raider_71
@aelqabbany  thank you for the reply. That would be a valid solution but in my case it's going to cause some issues as I have a downstream drawing with dimensions attached to the edges of the original extrusion, hence the reason for wanting to modify the extrusion.
Do you think it's an issue with the API or is there a property that I am missing?
Raider_71
I found the issue. You need to set the EOP (end of part) marker to above the extrude feature prior to editing its definition. Then it all works perfectly! I hope this helps someone else out there as I could not find anything online about the issue. ...after two days of searching, I found it in the sample code in the API help file... 😒
        oExtrude.SetEndOfPart(True)
        oExtrudeDef.SetToNextExtent(PartFeatureExtentDirectionEnum.kPositiveExtentDirection, oSurfBody)
        oCompdef.SetEndOfPartToTopOrBottom(False)
Cheers
