Easy way to constrain to iMate in Assembly
amichaudJ6E3R
amichaudJ6E3R
Hi, so I've used this a lot in the past, but from a part to another part inside an assembly.
Constraints.AddByiMates("Mate1", "Part1:1", "iMate:1", "Part2:1", "iMate:1")
Now, this is fairly simple and I like it. I've looked online and all I could find were paragraphs of VB code that are way too much for what I want.
I created an iMate in my assembly (connected to the origin XZ Plane) and I am trying to constrain, using the line above, a part's iMate to this assembly iMate. Is that possible?
Something like
Constraints.AddByiMates("Mate1", "Part1:1", "iMate:1", ThisAssembly, "iMate:1")
Thank you 🙂
-A
JhoelForshav
Hi @amichaudJ6E3R
Can you do this manually with the UI? I've tried it and I can't get the create an iMate result between an iMate in the main assembly and an iMate in an occurrence... So I don't think it works at all...
I'd suggest using AddByiMateAndEntity instead. Generally with these Constraints.Add - methods in iLogic, if you want to use something from the top assembly it's component argument is an empty string (""). So this will work for example:
Constraints.AddByiMateAndEntity("MateName", "Part1:1", "iMate:1", "", "XZ Plane")
amichaudJ6E3R
@JhoelForshav  - Thanks for the reply. I am ashamed to say that I did not try to do it manually, it seemed so trivial.
I will try the add by entity, I knew I could probably use something like this, but I never did in the past and couldn't find the proper syntax to call the root assembly and the plane. But you just enlighten my day, thank you for your help
amichaudJ6E3R
AAAAND it works. Exactly like I wanted to. Thanks a lot for your help. @JhoelForshav
