Dynamically generating shared variables
I have a program that places an unspecified number of parts in sequence and constrains them. However, many times it will place the same part multiple times. Until now I've just been picking the faces for the part over and over again but it occurred to me once I've picked the face on one part, the face should be named the same thing on all of the parts shouldn't it?
For some reason, however, when I attempt to tell the program to run, its just saying that there is no shared variable named that when I'm creating it. I realize I haven't figured out how to reference the part for the new faces either.
Can someone help me with declaring these shared variables, as well as telling it to reference the faces on the latest instance of the part? (I already have a code to locate the latest instance of the part that works however.)
'Pick Faces if Beams is input for first time '\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ Existence = False Dim Beams As New ArrayList Beams = MultiValue.List("BeamsWithDefinedFaces") 'Check if Beam has already been insterted before For Each oval in Beams If Parameter("FileName") = oval Then Existence = True Next 'If Beam is inserted for first time then pick faces and add beam to list If Existence = False Beams.Add(Parameter("FileName")) SharedVariable(Parameter("FileName") & "Face_Top") = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities, "Pick a flange") SharedVariable(Parameter("FileName") & "Face_Web") = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities, "Pick back of web") SharedVariable(Parameter("FileName") & "Face_End") = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities, "Pick face on end") End If 'Update Parameters MultiValue.List("BeamsWithDefinedFaces") = Beams '\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
If necessary, here is my code to locate the latest instance of the part. This one sets it to reference but I can easily change that I think
'Searches through assembly for a given file name, finds the latest instance of it, and turns it to reference layer. Function StringerReferenceChange(FileName) 'Set Active Assembly Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument 'Assembly definition Dim oAsmDef As AssemblyComponentDefinition oAsmDef = oAsmDoc.ComponentDefinition 'Component definition Dim oOcc As ComponentOccurrence 'Get all leaf occurrences of the assembly Dim oLeafOccs As ComponentOccurrencesEnumerator oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences 'Iterate through all of the occurrence in this collection, finds the latest occurrence, and sets it to reference Dim Instances As New ArrayList MaxValue = 0 Name = "None" For Each oOcc In oLeafOccs If Left(oOcc.Name,14) = FileName Then Instances.add(oOcc.Name) Next For Each oval in Instances If Val(Mid(oval, 16,3)) > MaxValue Then Name = oval Next For Each oOcc In oLeafOccs If oOcc.Name = Name Then Component.InventorComponent(oOcc.Name).BOMStructure = BOMStructureEnum.kReferenceBOMStructure Next End Function
