DXF Export with ilogic and save as location.
davis.j
davis.j
Can someone help me modify this code?
I am looking to use the standard behavior where it asks you where to save the DXF rather then a specified folder.
The code slightly changed to suit some of my needs but is near identical to this thread:
https://forums.autodesk.com/t5/inventor-customization/modify-layers-before-exporting-dxf-file-using-...
oDoc = ThisDoc.Document
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	oDoc = ThisApplication.ActiveDocument
	Dim oCompDef As SheetMetalComponentDefinition
	oCompDef = oDoc.ComponentDefinition
	If oCompDef.HasFlatPattern = False Then
		oCompDef.Unfold
	Else
		oCompDef.FlatPattern.Edit
	Dim sOut As String
	Dim oPath As String
	oPath = ThisDoc.Path & "\DXF Flat"
	If Not System.IO.Directory.Exists(oPath) Then
		System.IO.Directory.CreateDirectory(oPath)
	Dim sFname As String
	sOut = "FLAT PATTERN DXF?OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerLineType=37633&BendDownLayerColor=0;0;255&BendUpLayerLineType=37633&BendUpLayerColor=0;0;255IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES" _
		+ "&RebaseGeometry=True" _
		+ "&SimplifySplines=True" _
		+ "&SplineTolerance=0.01" _
	sFname = oPath & "\"& "myFile.dxf"
	oCompDef.DataIO.WriteDataToFile(sOut, sFname)
	Dim oSMDef As SheetMetalComponentDefinition
	oSMDef = oDoc.ComponentDefinition
	oSMDef.FlatPattern.ExitEdit
	MessageBox.Show("Your file was saved in the following dirctory: " + sFname)
	Else
		MessageBox.Show("Only sheet metal parts can be exported as DXF.")
I like to pick from my preset folders to select the save location. I also manually type in revision suffix's in the name of the file sometimes.
Is this possible?
Mike.Wohletz
I think you are looking to do something like this?
		oCompDef.Unfold
	Else
	Dim sOut As String
	Dim oPath As String
Dim sfd As New SaveFileDialog
sfd.Filter = "DXF Files (*.dxf*)|*dxf"
sfd.InitialDirectory = oPath
If sfd.ShowDialog = System.Windows.Forms.DialogResult.OK Then
	sFname = sfd.FileName
	Else
	MessageBox.Show("Your file was saved in the following directory: " + sFname)
	Else
davis.j
Yes, Thank you for your expertise. I have taken your codes and edited it further as it was still doing some funky folder shenanigan's that I had in there. Can you test this new code below and see if there is any issues for you?
The end goal of this illogic is to spit out a DXF while being able to select where to save it and specific the layers and other options. I will have to additionally open these DXF's with AutoCAD and make some other small edits as per the design intent but this will save me lots of time.
My other method involves opening the flat pattern in a drawing sheet and setting the bend up and then doing a save copy as. There is much more steps in my old method. Also the old method doesn't allow you to set the spline simplification and tolerance. I mainly am using that feature to cope with bad geometry or parts that for some reason include splines instead of polylines, lines and arc. Also sometimes with the splines in the bad geometry with the other DXF exports methods that do no come out as splines but rather a BAZILLION line entities which causes errors and machine malfunctions in production.
For parts without bends I usually right click on the face of the part and select "Export Face as..."
Do you know if there is any redundant or conflicting statements in the code? I will be testing this some more to see if any issues happen before I use this as a standard rule.
		oCompDef.Unfold
	Else
	Dim sOut As String
	Dim oPath As String
		sfd.FileName = iProperties.Value("Project", "Part Number")& ".dxf"
	Else
		sFname = oPath & "\"& ".dxf"
Else
davis.j
The code above works but only If I don't edit the filename when saving.
I like how it asks where you want to save the file but I cant change the filename. If I change the file name in the prompt the file gets created but comes out as a file with no extension. Then I have to add .dxf to the end.
I'd like to initially pull the part number but occasionally I have to make edits to the dxf filename. Examples:
  • "PART_NUMBER" -Rev2
  • "PART_NUMBER" -Laser
  • "PART_NUMBER"  test
I'm not sure exactly where I am going wrong.
Ralf_Krieg
Hello
Check if extension exist in filename and if not, add it. There may be a smarter way, but it works so far.
	Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
		oCompDef.Unfold
	Else
	Dim sOut As String ="FLAT PATTERN DXF?OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerLineType=37633&BendDownLayerColor=0;0;255&BendUpLayerLineType=37633&BendUpLayerColor=0;0;255IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES" _
	Dim oPath As String = ThisDoc.Path
	' makes no sense cause oPath is path of the current document
	' it either exist or is empty in case the document is not saved until now
	'If Not System.IO.Directory.Exists(oPath) Then
	'	System.IO.Directory.CreateDirectory(oPath)
	'End If
	If oPath = String.Empty Then
		MsgBox("Please save your document first.", , "iLogic Export Flat Pattern")
		Exit Sub
	sfd.Filter = "DXF Files (*.dxf)|*dxf"
		If Not Strings.Right(sFname, 4) = ".dxf" Then sFname = sFname & ".dxf"
	Else
		'User canceled out dialog
		Exit Sub
	oCompDef.FlatPattern.ExitEdit
Else
R. Krieg
RKW Solutions
www.rkw-solutions.com
