DXF export filename without sheet name
josh.linares-stanley
I have a script that renames each sheet name to the below format. My issue is that when a drawing is exported to DXF, this sheet name is automatically tagged on to the end of each dxf sheet file name. (Often long descriptions will make the filename too long to open in other programs).
Is there a way to revert back to having just the sequential sheet number for the DXF filenames only?
Below is the script I use for exporting to DXF
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
	If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
	Dim strIniFile As String
	strIniFile = "C:\temp\dxfout.ini"
	' Create the name-value that specifies the ini file to use.
	oOptions.Value("Export_Acad_IniFile") = strIniFile
'Set the destination file name
Dim IPJ As String
Dim IPJ_Name As String
Dim IPJ_Path As String
Dim FNamePos As Long
IPJ = ThisApplication.FileLocations.FileLocationsFile
FNamePos = InStrRev(IPJ, "\", -1)
IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos)
IPJ_Folder_Location = Left(IPJ, Len(IPJ) -Len(IPJ_Name))
'Sets the Dirctory that the PDF should be saved in
DXFPath = IPJ_Folder_Location & "DXF" & "\" & ThisDoc.FileName(False) & "-rev" & iProperties.Value("Project", "Revision Number")
DXFName = DXFPath & "\" & ThisDoc.FileName(False) & "-rev" & iProperties.Value("Project", "Revision Number") & ".dxf"
'Set the DXF target file name
oDataMedium.FileName = DXFName
MessageBox.Show(DXFName, "Title")
'Checks to see if that directory exists, if not, it is created
If(Not System.IO.Directory.Exists(DXFPath)) Then
	System.IO.Directory.CreateDirectory(DXFPath)
oDataMedium.FileName = DXFName 'same folder, or uncomment:
'oDataMedium.FileName = "C:\myDXFfolder\" & ThisDoc.FileName(False) & ".dxf" 'fixed folder
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Launch the dxf file in whatever application Windows is set to open this document type with
i = MessageBox.Show("Preview the DXF file?", "Title",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
dalton98
Edit: Sorry, the code I posted wouldn't work with how you have it set up. You would need to somewhere in your code open up the drawing document and search each sheet until you get a match. It would look something like this:
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.Documents.Open("drawing.idw", True)
oDrawingDoc.Activate()
Dim oSheet As Sheet
Dim oSheetNumber As String
For Each oSheet In oDrawingDoc.Sheets
	If InStrRev(oSheet.Name, iProperties.Value("Project", "Part Number")) > 0
		 oSheetNumber = "Sheet:" & Right(oSheet.Name, 1)
Next
oDrawingDoc.Close
'your code------------------------ DXFName = DXFPath & "\" & oSheetNumber & "-rev" & iProperties.Value("Project", "Revision Number") & ".dxf"
Hi, Thanks for the reponse. I think I have found a work around for this. I've added a subroutine at the start which simply renames each sheet back to "SHT". After the drawing has exported, the document saves which re-executes the "sheet-renamer" script.
