DXF CREATION WITH PART NUMBER ENGRAVED
jerinc101
jerinc101
Hi All,
I need to create ilogic for dxf creation with engraved part number of part and assembly. I have modified an ilogic from other thread. but its not working. can you please modify anyone. Thanks in advance.
Sub Main()
  	Dim myDate As String = Now().ToString("yyyy-MM-dd HH:mm:ss")
	myDate = myDate.Replace(":", ".")
	'change this as needed
	oRoot = ThisDoc.Path
	'oRoot = ThisDoc.Path 'use the document's containing folder path
	oSuffix = "DXF"
	'oSuffix = iProperties.Value("Project", "Project") 'use the document's Project#
	'oSuffix = iProperties.Value("Project", "Part Number") 'use the document's Part#
	'get target folder path
	oFolder = oRoot & "\" & oSuffix & " (" & myDate & ")"
	'Check for the PDF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	'open the folder
	Process.Start(oFolder)
	Dim oDoc As Document
	oDoc = ThisApplication.ActiveDocument
	'PDF of the file you're running it this from
	'Loop through all referenced documents
	j= 1
	For Each oDoc In ThisApplication.ActiveDocument.AllReferencedDocuments
		oName = oDoc.DisplayName
		ck = j Mod 2
		If ck = 0 Then
			oFlicker = ".......... "
		Else
			oFlicker = ".... "
		ThisApplication.StatusBarText = "Processing DXF" & oFlicker & oName
		j = j + 1
		'created DXF's of sheetmetal parts
		Call DXF_Out(oDoc, oFolder)
	Next
	ThisApplication.StatusBarText = "Done!!!!!"
End Sub
Sub DXF_Out(ByRef oDoc As Document, oFolder As String)
	oCreated_Flat = False
	oFullFileName = oDoc.FullFileName
	oFileName = Right(oFullFileName, Len(oFullFileName) - InStrRev(oFullFileName, "\"))
	oName = Left(oFileName, InStrRev(oFileName, ".") - 1) 'name without extension
	'look at only Sheet metal parts
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Logger.Info("File Name: " & oFileName)
		Logger.Info("Is Sheetmetal")
		Dim oCompDef As SheetMetalComponentDefinition
		oCompDef = oDoc.ComponentDefinition
		i = 0
		Logger.Info("Looking at solid bodies....")
		For Each oBody In oCompDef.SurfaceBodies
			If oBody.IsSolid = True Then
				i = i +1
		Next
		If i > 1 Then
		 	Exit Sub
		Logger.Info(".....solid bodies ok")
		'check for flat pattern
		If oCompDef.HasFlatPattern = False Then
			Logger.Info("HasFlatPattern: " & oCompDef.HasFlatPattern)
			Logger.Info("/////////////\\\\\\\\\\\\ Trying to create flatpattern...")
			Try
				oCompDef.Unfold
				oCreated_Flat = True
			Catch ex As Exception
				Logger.Info("Problem creating flat!!!!")
				Logger.Info(ex.Message)
			End Try
		Else 'if flat pattern exists
			Logger.Info("Trying to get flatpattern...")
			ThisApplication.Documents.Open(oFullFileName, True)
			Try
				oCompDef.FlatPattern.Edit
				Logger.Info("Problem editing flat!!!!")
			End Try
	Dim sOut As String
      sOut = "FLAT PATTERN DXF?AcadVersion=2018" _
	  + "&BendUpLayer=IV_BEND" _
	  + "&BendDownLayer=IV_BEND_DOWN" _
	  + "&BendUpLayerColor=255;0;255" _
	  + "&BendDownLayerColor=255;0;255" _
	  + "&FeatureProfilesUpLayer=IV_FEATURE_PROFILES" _
	  + "&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN" _
	  + "&FeatureProfilesUpLayerColor=0;255;255" _
	  + "&FeatureProfilesDownLayer=0;255;255" _
	  + "&OuterProfileLayer=IV_OUTER_PROFILE" _
	  + "&OuterProfileLayerColor=0;255;255" _
	  + "&InteriorProfilesLayer=IV_IV_INTERIOR_PROFILES" _
	  + "&InteriorProfilesLayerColor=0;255;255" _
	  + "&InvisibleLayers=IV_TANGENT;IV_ROLL_TANGENT;IV_TOOL_CENTER;IV_ARC_CENTERS;IV_TOOL_CENTER_DOWN"
	'EINDE TOEVOEGING
	Dim oCommand As CommandManager = ThisApplication.CommandManager
	sFullDXFname = oFolder & "\" & oName & ".dxf"
	oCompDef.DataIO.WriteDataToFile(sOut, sFullDXFname)
Try
			Logger.Info("DXF created!!!:  " & sFullDXFname)
			Logger.Info("Problem creating DXF!!!!")
		End Try
		oCompDef.FlatPattern.ExitEdit
		Try
			If oCreated_Flat = True Then oDoc.Save
			Logger.Info("Saving the file.")
		End Try
		oDoc.Close
		Logger.Info("*******************")
End Sub
Public Function AddDXFProperties(Optional JustReturnText As Boolean = False) As String
Dim PartNumber As String = "PartNumber: " & UCase(iProperties.Value("Project", "Part Number")) 'false = without extension '(iProperties.Value("Project", "Part Number")) 'without extension
Dim sText As String = PartNumber
If JustReturnText = False Then
	extents_length = SheetMetal.FlatExtentsLength
	extents_width = SheetMetal.FlatExtentsWidth
	PosX = extents_length/2
	PosY = extents_width/-2
	Call EditDXFFile(PartNumber, PosX, PosY, FullDXFname, "1D5")
AddDXFProperties = sText
End Function
Public Sub EditDXFFile(TextToAdd As String, PosX As Double, PosY As Double, FullDXFname As String, IDnumber As String)
	Dim RequiredText As String =  "TEXT" _
		& vbNewLine & "  5" _
		& vbNewLine & IDnumber _
		& vbNewLine & "330" _
		& vbNewLine & "71" _
		& vbNewLine & "100" _
		& vbNewLine & "AcDbEntity" _
		& vbNewLine & "  8" _
		& vbNewLine & "0" _
		& vbNewLine & "AcDbText" _
		& vbNewLine & " 10" _
		& vbNewLine & PosX _
		& vbNewLine & " 20" _
		& vbNewLine & PosY _
		& vbNewLine & " 30" _
		& vbNewLine & "0.0" _
		& vbNewLine & " 40" _
		& vbNewLine & "3.55" _ 'Text Height
		& vbNewLine & "  1" _
		& vbNewLine
	Dim realTextToAdd As String = RequiredText & TextToAdd _
		& vbNewLine & "0" _
		& vbNewLine
	Dim textLen As Integer = realTextToAdd.Length()
	FullDXFname = ThisDoc.FileName(False)
	oPath = ThisDoc.Path
	sFname = oPath & "\" & FullDXFname & ".dxf"
	Dim readText As String = System.IO.File.ReadAllText(oFilename)
	Dim re As New System.Text.RegularExpressions.Regex("(?<=ENTITIES((?!ENDSEC).)*)ENDSEC", System.Text.RegularExpressions.RegexOptions.Singleline)
	Dim i As Integer = 0
	For Each match In re.Matches(readText)
		readText = readText.Insert(match.Index + textLen * i, realTextToAdd)
		i = i + 1
	Next
	System.IO.File.WriteAllText(FullDXFname, readText)
End Sub
daltonNYAW9
Heres a good example of how to add a 'Mark feature' to a part:
http://www.hjalte.nl/82-addmarkfeature
You will need to change the 'PartComponentDefinition' to a 'FlatPattern' so the mark will only show up on the flat pattern. I got it to work only chaning a few lines from the above link:
Dim doc As PartDocument = ThisDoc.Document
Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
Dim face As Face = def.FlatPattern.TopFace
Dim pointOnFace As Point = ThisApplication.TransientGeometry.CreatePoint(1, 2, 0)
'Private Sub CreateMarkFeatur
Dim markFeatures As MarkFeatures = def.FlatPattern.Features.MarkFeatures
'End Sub
