Duplicate Occurrence with Sketch Driven Pattern
HogueOne
HogueOne
I'm trying to duplicate an occurrence and constrain a work point nested in one of its subcomponents to each work point in a sketch driven pattern the user picks. Most of the code is working correctly. It duplicates the occurrence as many times as there are points in the sketch driven pattern. but I keep getting this error:
"Error adding mate constraint: Public member 'Position' on type 'FeaturePatternElementProxy' not found."
I'm using AI to help me write these codes, so please forgive me if the code looks wonky. How can I fix this so the constraints work with the sketch driven pattern points?
Here's the not-working correctly code:
Sub Main()
    ' Prompt the user to select an assembly in the active document
    Dim oSelectedEntity As Object
    oSelectedEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a subassembly in the model browser.")
    ' Check if the user selected a component occurrence
    If oSelectedEntity Is Nothing OrElse Not TypeOf oSelectedEntity Is ComponentOccurrence Then
        MessageBox.Show("No subassembly selected. Exiting script.", "No Selection")
        Exit Sub
    ' Extract file name and location from the selected assembly occurrence
    Dim oCompOcc As ComponentOccurrence
    oCompOcc = oSelectedEntity
    Dim assemblyDoc As Document = oCompOcc.Definition.Document
    Dim assemblyFileName As String = assemblyDoc.FullFileName
    Dim assemblyLocation As String = System.IO.Path.GetDirectoryName(assemblyFileName)
    ' Get the part number of the original part
    Dim partNumber As String = oCompOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
    ' Get active assembly document
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    ' Create a browser folder with the part number and get the folder object
    Dim oFolder As BrowserFolder
    oFolder = CreateBrowserFolder(oDoc, partNumber)
    ' Get the browser pane
    Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane
    ' Prompt the user to select a sketch-driven pattern
    Dim oPattern As SketchDrivenPatternFeature
    oPattern = PromptForSketchDrivenPattern(oDoc)
    If oPattern Is Nothing Then
        MessageBox.Show("No sketch-driven pattern selected. Exiting script.", "No Selection")
        Exit Sub
    ' Process each active element in the pattern
    For Each oElement As Object In oPattern.PatternElements
        If Not oElement.Suppressed Then
            ' Add selected assembly as a component to the active assembly
            Dim oCompDef As ComponentDefinition
            oCompDef = oDoc.ComponentDefinition
            ' Duplicate the selected occurrence (oCompOcc)
            Dim oDuplicateOcc As ComponentOccurrence
            oDuplicateOcc = DuplicateOccurrence(oCompOcc, oCompDef)
            ' Add angle constraints between oCompOcc and oDuplicateOcc
            Call ApplyAngleConstraints(oCompOcc, oDuplicateOcc, oDoc.ComponentDefinition, 0)
            ' Move the duplicate occurrence to the new folder
            If oFolder IsNot Nothing Then
                Call AddtoFolder(oFolder, oDuplicateOcc, oPane)
            ' Find sheet metal suboccurrence and add mate constraint
            Dim constraintAdded As Boolean = AddMateConstraintToPatternElement(oDoc, oDuplicateOcc, oElement)
            If Not constraintAdded Then
                ' If constraint wasn't added, skip to the next element
                Continue For
    Next
    ' Save the document to update changes
    oDoc.Save()
    MsgBox("Process completed. Document saved.", vbInformation)
End Sub
Function PromptForSketchDrivenPattern(oDoc As AssemblyDocument) As SketchDrivenPatternFeature
    Dim oPattern As Object
    Try
        oPattern = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select a sketch-driven pattern")
            Return Nothing
        If TypeOf oPattern Is SketchDrivenPatternFeature Then
            Return DirectCast(oPattern, SketchDrivenPatternFeature)
        Else
            MessageBox.Show("Selected pattern is not a sketch-driven pattern. Please select a sketch-driven pattern.", "Invalid Selection")
            Return Nothing
    Catch ex As Exception
        MessageBox.Show("Error selecting sketch-driven pattern: " & ex.Message, "Error")
        Return Nothing
    End Try
End Function
Function AddMateConstraintToPatternElement(oDoc As AssemblyDocument, oDuplicateOcc As ComponentOccurrence, oElement As Object) As Boolean
    Dim oTrans As Transaction = Nothing
    Try
        oTrans = ThisApplication.TransactionManager.StartTransaction(oDoc, "Add Mate Constraint to Pattern Element")
        ' Find the sheet metal suboccurrence
        Dim oSheetMetalOcc As ComponentOccurrence = FindSheetMetalSuboccurrence(oDuplicateOcc)
        If oSheetMetalOcc Is Nothing Then
            MsgBox("No sheet metal suboccurrence found in the duplicated assembly.")
            oTrans.End()
            Return False
        ' Get the origin work point of the sheet metal occurrence
        Dim oOriginWorkPoint As WorkPoint
        oOriginWorkPoint = oSheetMetalOcc.Definition.WorkPoints.Item(1)  ' Assuming the first work point is the origin
        ' Create a proxy for the origin work point
        Dim oOriginProxy As WorkPointProxy
        oSheetMetalOcc.CreateGeometryProxy(oOriginWorkPoint, oOriginProxy)
        ' Get the position of the pattern element
        Dim oPosition As Point
        If TypeOf oElement Is FeaturePatternElement Then
            oPosition = DirectCast(oElement, FeaturePatternElement).Position
        ElseIf oElement.HasProperty("Position") Then
            oPosition = oElement.Position
        Else
            MsgBox("Unable to get position from pattern element.")
            oTrans.End()
            Return False
        ' Create a work point at the location of the pattern element
        Dim oPatternPoint As WorkPoint = oDoc.ComponentDefinition.WorkPoints.AddByPoint(oPosition)
        ' Add mate constraint
        Dim oConstraints As AssemblyConstraints = oDoc.ComponentDefinition.Constraints
        oConstraints.AddMateConstraint(oOriginProxy, oPatternPoint, 0)
        oTrans.End()
        Return True
        If Not oTrans Is Nothing Then
            oTrans.Abort()
        MsgBox("Error adding mate constraint: " & ex.Message)
        Return False
    End Try
End Function
Function DuplicateOccurrence(sourceOcc As ComponentOccurrence, compDef As ComponentDefinition) As ComponentOccurrence
    Dim oDuplicateOcc As ComponentOccurrence = Nothing
    Try
        oTrans = ThisApplication.TransactionManager.StartTransaction(compDef.Document, "Duplicate Occurrence")
        ' Create a matrix for positioning the duplicate occurrence
        Dim oMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
        oMatrix.SetToIdentity()
        ' Get existing occurrence names in the assembly
        Dim existingNames As New List(Of String)
        For Each occ As ComponentOccurrence In compDef.Occurrences
            existingNames.Add(occ.Name)
        Next
        ' Determine the new name for the duplicate occurrence
        Dim baseName As String = sourceOcc.Name & "-COPY-001"
        Dim newName As String = baseName
        Dim count As Integer = 1
        Do While existingNames.Contains(newName)
            count += 1
            newName = baseName.Substring(0, baseName.Length - 4) & "-" & count.ToString("000")
        Loop
        ' Add the duplicate occurrence
        oDuplicateOcc = compDef.Occurrences.Add(sourceOcc.Definition.Document.FullFileName, oMatrix)
        ' Set BOM structure to reference
        oDuplicateOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
        ' Set the unique name
        oDuplicateOcc.Name = newName
        oTrans.End()
            oTrans.Abort()
        MessageBox.Show("Error duplicating occurrence: " & ex.Message, "Error")
    End Try
    Return oDuplicateOcc
End Function
Sub ApplyAngleConstraints(O1 As ComponentOccurrence, O2 As ComponentOccurrence, aCD As ComponentDefinition, angleValue As Double)
    On Error GoTo EER
    Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(aCD.Document, "Constraint Creation")
    ' Setup Proxies
    Dim wPlane1 As WorkPlaneProxy
    Dim wPlane2 As WorkPlaneProxy
    ' Run for 3 origin planes
    For i = 1 To 3
        O1.CreateGeometryProxy(O1.Definition.WorkPlanes.Item(i), wPlane1)
        O2.CreateGeometryProxy(O2.Definition.WorkPlanes.Item(i), wPlane2)
        ' Create angle constraint
        Dim angleConst As AngleConstraint = aCD.Constraints.AddAngleConstraint(wPlane1, wPlane2, angleValue)
    Next
    oTrans.End
    Exit Sub
EER:
    oTrans.Abort
End Sub
Function CreateBrowserFolder(oDoc As Document, folderName As String) As BrowserFolder
    Dim oTopNode As BrowserNode = oPane.TopNode
    Dim oFolder As BrowserFolder = Nothing
    ' Try to find the folder, if it doesn't exist, create it
    Try
        oFolder = oTopNode.BrowserFolders.Item(folderName)
    Catch
        oFolder = oPane.AddBrowserFolder(folderName)
    End Try
    Return oFolder
End Function
Sub AddtoFolder(oFolder As BrowserFolder, oSelectedEntity As Object, oPane As BrowserPane)
    Dim oNode As BrowserNode
    ' Add the selected component to the folder
    If TypeOf oSelectedEntity Is ComponentOccurrence Then
        Dim oOcc As ComponentOccurrence
        oOcc = oSelectedEntity
        oNode = oPane.GetBrowserNodeFromObject(oOcc)
        oFolder.Add(oNode)
End Sub
Function AddMateConstraintToSheetMetalOrigin(oDoc As AssemblyDocument, oDuplicateOcc As ComponentOccurrence, oWorkPoint As Object) As Boolean
    Try
        oTrans = ThisApplication.TransactionManager.StartTransaction(oDoc, "Add Mate Constraint to Sheet Metal Origin")
            oTrans.End()
            Return False
        oConstraints.AddMateConstraint(oWorkPoint, oOriginProxy, 0)
        oTrans.End()
        Return True
            oTrans.Abort()
        Return False
    End Try
End Function
Function FindSheetMetalSuboccurrence(oOcc As ComponentOccurrence) As ComponentOccurrence
    ' Check if the current occurrence is a sheet metal part
    If TypeOf oOcc.Definition Is SheetMetalComponentDefinition Then
        Return oOcc
    ' If not, search through suboccurrences
    For Each subOcc As ComponentOccurrence In oOcc.SubOccurrences
        Dim result As ComponentOccurrence = FindSheetMetalSuboccurrence(subOcc)
        If result IsNot Nothing Then
            Return result
    Next
    ' If no sheet metal suboccurrence is found, return Nothing
    Return Nothing
End Function
And here's the code that works correctly but only allows me to duplicate one at a time:
Sub Main()
        Exit Sub
    ' Main loop for repeating the process
    Do
        ' Prompt the user to select a work point for mate constraint
        Dim oWorkPoint As Object
        oWorkPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Select a work point for mate constraint or press Esc to exit")
        If oWorkPoint Is Nothing Then
            ' User pressed Esc, exit the loop
            Exit Do
        Dim constraintAdded As Boolean = AddMateConstraintToSheetMetalOrigin(oDoc, oDuplicateOcc, oWorkPoint)
            ' If constraint wasn't added, exit the loop
            Exit Do
    Loop
    oDoc.Save()
End Sub
    Try
        Next
            count += 1
        Loop
        oTrans.End()
            oTrans.Abort()
    End Try
End Function
    On Error GoTo EER
    ' Setup Proxies
    For i = 1 To 3
    Next
    oTrans.End
    Exit Sub
EER:
    oTrans.Abort
End Sub
    Try
    Catch
    End Try
    Return oFolder
End Function
        oFolder.Add(oNode)
End Sub
    Try
            oTrans.End()
            Return False
        oTrans.End()
        Return True
            oTrans.Abort()
        Return False
    End Try
End Function
        Return oOcc
            Return result
    Next
    Return Nothing
End Function
A.Acheson
Hi @HogueOne
If you have a sequence that works once and you want it to repeat you will need some sort of loop and release for the user to end when they need to. This can be done with a message box and conditions to exit the loop. I suggest you start looking at these tools. There are many on this forum. While AI tools can be powerful, they can leave holes in basic steps the coder should be able to do if they learned the basics.
If you have trouble implementing a loop one conditions attach them as a question.
Regards
Alan
