Driving parameters of components with models states, at assembly level
vmat8888
vmat8888
I am trying to drive "Length" parameter of "Slotted Strut.ipt" component,part of an assembly, using iLogic. Slotted Strut.ipt component, has different models states, BUT the "Length" is the same for all of them (other parameters are different).
At assembly level,I created the user parameter "Strut_Lenth", through which I am trying to control "Length" parameter in Slotted Strut component.
I tried each of the two lines of code below, but both give me errors.
I would appreciate your help. Thank you.
Parameter("Slotted Strut:1", "Length") = Strut_Length
Parameter("Slotted Strut:1","Model State1", "Length") = Strut_Length
JelteDeJong
It's not pretty but I think it does what you need:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim occ1 = doc.ComponentDefinition.Occurrences.ItemByName("Slotted Strut:1")
Dim occDef = occ1.Definition
Dim modelStateUtil As ModelStateUtils = New ModelStateUtils()
Dim masterModelStateDocument As PartDocument = modelStateUtil.GetFactoryDocument(occ1.Definition.Document)
Dim masterModelStateDef = masterModelStateDocument.ComponentDefinition
masterModelStateDef.ModelStates.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
Dim para As Parameter = masterModelStateDef.Parameters.UserParameters.Item("Length")
para.Expression = Strut_Length
Jelte de Jong
Blog: hjalte.nl - github.com
vmat8888
Hi JelteDeJong,
Thank you, but still I get an error in line below, saying Invalid parameter.
Just a short expenation again. In Slotted Strut.ipt, I have three different Model States, Model State1, 2 and 3. They have other different parameters, BUT "Height" is the same for all three model states. I need to drive Length in Slotted Strut.ipt, through user parametyer Strut_Length in the assembly level.
Thank you.
Dim para As Parameter = masterModelStateDef.Parameters.UserParameters.Item("Length ")
