DrawingView Label Positions
NachoShaw
Advisor Advisor
NachoShaw
Hey
Using the exact same code, i get different results with the positions of Drawing View Labels. In the images below the red dash line indicated the left of the drawing view.
There is a clear difference in the position, why is this? It looks like even though the tesxt is justified left and the label is also justified left, the label itself is positioned from the center of the label. Is there a method to get the width of the label As i could calculate that to get its left side of the label. I did look at the Label.RangeBox but my results placed the labels off page...
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
WCrihfield
Jut to be clear, you've already used:
oView.Label.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextRight
and set:
oView.Label.TextStyle =
to a TextStyle that is pre-defined as being left aligned?
Have you tried using:
oView.Label.FormattedText =
to independently specify the formatting of the text?
I'm not entirely sure if alignment &/or justification can be manipulated using FormattedText, but if you're not familiar with using FormattedText, it uses XML type code.  Below is one of many references for it.
XML Tags for FormattedText
Wesley Crihfield
(Not an Autodesk Employee)
NachoShaw
hey
Thanks for the reply
Yes, I had used all of that. I can to realize that even though the text gets justified, the label itsf remains positioned from a center point. I ended up using the Label.Rangebox.maxpoint and midpoint to calculate the label length and deduct that from the view width
Nacho
