Drawing view needs updating
FINET_Laurent
Advisor Advisor
FINET_Laurent
Morning eveyrone,
I whould like to know where I can find if a view needs it's model to be updated or not.. as a boolean if possible.
I mean this :
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
dutt.thakar
Hello @FINET_Laurent ,
Just a quick code, which indicates which view needs updating in a message box. If this is something you are looking for.
Try this code, Which Iterates through all the views in drawing and checks whether they are updated or not.
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
For Each oView As DrawingView In oSheet.DrawingViews
	If oView.UpToDate = True
		MessageBox.Show(oView.Name)
Next
You can modify this code to suit your requirements, like showing all the views in one Message box, currently I have not done that, but this will give you idea probably on what you are looking for, If I have understood correctly.
If this has answered your question, please accept this as solution.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
FINET_Laurent
The code isn't making a difference between up to date views and not up to date views.
I already looked through the view object but I don't think this is the place to search.. 🤔
AlexKorzun
Maybe you need checking DrawingView.ReferencedDocumentDescriptor.ReferencedDocument.RequiresUpdate ?
Some of the components in the chain above could result in null (Nothing) for the particular drawing view type or state.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
ernis
@AlexKorzun   or maybe you could write iLogic code to update all the ones you need to update? Maybe it would be better than getting a list and updating manually. Thank you in advance
FINET_Laurent
I Managed this code with @AlexKorzun 's help. 🙂
Dim oView As DrawingView
For Each oView In oDoc.ActiveSheet.DrawingViews
	Dim bBoolean As Boolean = oView.ReferencedDocumentDescriptor.ReferencedDocument.RequiresUpdate
	If bBoolean = True Then
		Dim Pathfile As String = oView.ReferencedDocumentDescriptor.FullDocumentName
		Dim xDoc As Document
			xDoc = ThisApplication.Documents.Open(Pathfile, True)
			xDoc.Update
			xDoc.Save
			xDoc.Close
Next
MessageBox.Show("All drawing views are up do date", "Baguette",Nothing,MessageBoxIcon.Asterisk )
FINET L.
