Drawing view doesnt UPDATE
m_baczewski
Message 1 of 12
m_baczewski
In the drawing, I have 3 sheets. The rule works in such a way that when changing elements and parts in the assembly, the drawing should update and add balloons to the elements that appear. The problem is that it tries to add balloons on a sheet other than the first one, and on those sheets, I get an error that a certain edge doesn't exist. This is because the drawing hasn't updated yet. Only views on the first sheet are updating. When I check the UpToDate property, it appears that only views on the first sheet have True, while all views on other sheets have False. I've already tried:
oDoc.Update
oDoc.Update2
ThisApplication.ActiveDocument.Update
ThisApplication.ActiveDocument.Update2
InventorVb.DocumentUpdate()
None of these elements work. If I manually trigger the rule again, then it works fine. At this point, the rule is triggered during 'Drawing view change'. Do you have any idea?
Replies (11)
Message 2 of 12
FINET_Laurent
Hello @m_baczewski,
Have you tried activating the drawing document first, then looping through each sheet ->  activating the actual sheet -> using the sheet.Update() instead?
Inventor 2024 Help | Sheet Object | Autodesk
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 12
m_baczewski
@FINET_Laurent
Yeah i have tried this one:
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
For Each oSheet As Sheet In oDoc.Sheets
	oSheet.Activate
	For Each oDrawingViews As DrawingView In oSheet.DrawingViews
		Logger.Info(oDrawingViews.UpToDate)
	Next
	oSheet.Update()
Next
 UpToDate=True is always for views on the sheet that was active when the automatic rule was triggered. For example, if I change the model and leave the drawing on sheet 3, the views on sheet 3 will have UpToDate=True.
Message 4 of 12
FINET_Laurent
@m_baczewski,
On this code, you are checking the update status  of the drawing view before updating the sheet. 🤔 Can you try this instead? :
	oSheet.Activate
	oSheet.Update()
	Next
Next
Kind regards,
FINET L.
Message 5 of 12
m_baczewski
@FINET_Laurent
It`s still nothing. After executing the rule, still 2 out of 3 sheets have a lightning and their UpToDate=False.
Message 6 of 12
FINET_Laurent
@m_baczewski,
Then it depends of what needs to be updated. Have you tried the rebuild method the documents ?
Inventor 2024 Help | Document.Rebuild Method | Autodesk
Kind regards,
FINET L.
Message 7 of 12
m_baczewski
@FINET_Laurent
When i`m trying to use Rebuild i have got a error "Not implemented. (Exception from HRESULT: 0x80004001 (E_NOTIMPL))" or "Class undefined"
Dim oDoc As DrawingDocument = ThisDoc.Document
oDoc.Rebuild()
Message 8 of 12
Sergio.D.Suárez
I think You must first update the part and assembly models that are represented by the views
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 9 of 12
m_baczewski
@Sergio.D.Suárez
When I change configurations in the model, it automatically updates the model at the very end.
RuleParametersOutput()
oDoc.Update
iLogicVb.UpdateWhenDone = True
Message 10 of 12
m_baczewski
I will describe strange behavior when I change model configurations and go to the drawing
The rule automatically triggers because I have it set to run when the drawing view changes.
In this rule, I have:
oDoc = ThisDoc.Document
oDoc.Sheets.Item(2).Update
Unfortunately, this doesn't work.
But I also have this part of the code in a TEST rule, and when I run the rule manually, it updates the sheet normally. Something blocked document update. What could be the cause of this?
Message 11 of 12
m_baczewski
It seems a bit like the automatic drawing update, which occurs after updating the model, is blocking the sheet update.
Maybe @WCrihfield or @A.Acheson can explain the weird behaviour?
Message 12 of 12
WCrihfield
Hi @m_baczewski.  @FINET_Laurent & @Sergio.D.Suárez already suggested most of what I would have suggested.  But now that I have seen the code you had in your Event Triggers dialog under the 'Drawing View Change' event, I would suggest changing that code a bit, so that it iterates through each sheet, activates it, updates it, then re-activates the original sheet again, sort of like the following example:
Sub Main
	Dim oDDoc As DrawingDocument = TryCast(ThisDoc.Document, Inventor.DrawingDocument)
	If oDDoc Is Nothing Then Return
	ThisDoc.ModelDocument.Update2(True)
	oDDoc.Update2(True)
	Dim oASheet As Sheet = oDDoc.ActiveSheet
	For Each oSheet As Sheet In oDDoc.Sheets
		oSheet.Activate
		oSheet.Update
	Next
	oASheet.Activate
	oDDoc.Update2(True)
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
