Drawing Symbol library unable to close
w.pepping
w.pepping
I hope someone can help me with this.
I'm trying to query through code how many Sketched Symbols are present in the Symbol Library folder (MySymbolLib.idw). This works and I get this info in the message box. But as soon as the messagebox is shown, a document (probably MySymbolLib.idw) opens invisible and I can't close it anymore.
How can I do this by code?
If I place 1 or more Sketched Symbols then this invisible document is closed correct.
The problem is only there if I quit without placing.
        Dim oDrawDoc As DrawingDocument = _invApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, , False)
        Dim oSymbolLibs As SketchedSymbolDefinitionLibraries = oDrawDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries
        Dim oSymbolLib As SketchedSymbolDefinitionLibrary = oSymbolLibs.Item("MySymbolLib")
MsgBox(oSymbolLib.SketchedSymbolDefinitions.Count)
        oDrawDoc.ReleaseReference()
        oDrawDoc.Close(True)
Get control of your sheet metal files.
Download the app from matprop.com
JelteDeJong
you can try
ThisApplication.Documents.CloseAll()
Jelte de Jong
Blog: hjalte.nl - github.com
Scott_Stubbington
I may have missed a point but in my head you are opening a document, not adding a document, personally myself I would change
to
Dim oDrawDoc As DrawingDocument = _invApp.Documents.Open("Filename to MySymbolLib.idw here", False)
The picture in my head is you've just created a new file from your template drawing file and closing a new file without saving might be the issue.  I feel the remaining code should work.
I hope this helps.
Scott
w.pepping
Thanks Jelte, Scott, I appreciate the replies.
I figured out that after I do a request for information from the symbol library (MySymbolLib.idw), it is opened in the background.
If I do not insert a symbol (not possible in my case, because I do the request from a ipt/iam) it is never closed and causes an error if I exit Inventor.
So I have to close it by code after the request:
        For Each openDoc As Document In _invApp.Documents
            If IO.Path.GetFileNameWithoutExtension(openDoc.FullFileName) = "MySymbolLib" Then
                openDoc.Close(True)
                Exit For
        Next
