Drawing sketch line linked to work plane
malmal02122023
Message 1 of 32
malmal02122023
Could you help me please?
I am new in VBA ilogic
I would like to link a sketch line to work plane with offset 20 mm and use it to create section line.
I understand that the code shown below draws a line on the base view relative to its center.
Question: how can  build a line relative to the work plane located in the model and named A-A.
Thanks for advice
Dim SectionPoint_L As Point2d = oTG.CreatePoint2d(Left_X, oBaseView.Center.Y)
	Dim SectionPoint_R As Point2d = oTG.CreatePoint2d(Right_X, oBaseView.Center.Y)
	Dim SheetPoint_L As Point2d = SectionSketch.SheetToSketchSpace(SectionPoint_L)
	Dim SheetPoint_R As Point2d = SectionSketch.SheetToSketchSpace(SectionPoint_R)
	Dim SketchLine As Inventor.SketchLine = SectionSketch.SketchLines.AddByTwoPoints(SheetPoint_L, SheetPoint_R)
Replies (31)
Message 21 of 32
A.Acheson
You have two options, offset or 2pointdistance. Offset would be easiest as it just needs two lines so very easy.
drawing sketch dimension constraint help page here
Syntax
DimensionConstraints.AddOffset( Line As SketchLine, Entity As SketchEntity, TextPoint As Point2d, LinearDiameter As Boolean, [Driven] As Boolean ) As OffsetDimConstraint
Syntax
DimensionConstraints.AddTwoPointDistance( PointOne As SketchPoint, PointTwo As SketchPoint, Orientation As DimensionOrientationEnum, TextPoint As Point2d, [Driven] As Boolean ) As TwoPointDistanceDimConstraint
For use with sketch line to get the sketch point.
Syntax
SketchLine.StartSketchPoint() As SketchPoint
Regards
Alan
Message 22 of 32
A.Acheson
Here is one method to achieve this. Projecting the workplane to the sketch was difficult, you need to pick up the centerline in the drawing view to use as the entity. Simply using the workplaneproxy did not work.
Once you have it working I suggest you make functions/sub routines in order to reuse objects as you can see there is some repetition setting in. The code below is clean up in terms of using consistent variable naming change as you would like.
Sub Main()
    Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheet As Sheet = oDoc.ActiveSheet
    Dim oFirst_view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Please select the main view")
    If oFirst_view Is Nothing Then Exit Sub
    If Not oFirst_view.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then Exit Sub
	Dim oComp As AssemblyDocument = oFirst_view.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oOcc As ComponentOccurrence = oComp.ComponentDefinition.Occurrences.ItemByName("Skeleton test:1")
	Dim oSkeletonDoc As PartDocument = oOcc.Definition.Document
	Dim wpList As New List(Of String)
	Dim oWp As WorkPlane
	For Each oWp In oSkeletonDoc.ComponentDefinition.WorkPlanes
	      wpList.Add(oWp.Name)
	Next
	Dim wpSel As String = InputListBox("Work planes found", wpList, "", "Select work plane", "work plane found")
	If String.IsNullOrEmpty(wpSel) Then Return
	oWp = oSkeletonDoc.ComponentDefinition.WorkPlanes(wpSel)
	Dim oWPlaneProxy As WorkPlaneProxy
	oOcc.CreateGeometryProxy(oWp, oWPlaneProxy)
	oFirst_view.SetIncludeStatus(oWPlaneProxy, True)
	oFirst_view.SetVisibility(oWPlaneProxy, False)
	Dim oSketch As DrawingSketch = oFirst_view.Sketches.Add
	oSketch.Edit()
	Dim oCenterLine1 As SketchLine
	For Each oCenterline As Centerline In oSheet.Centerlines
		If oCenterline.ModelWorkFeature Is oWPlaneProxy Then
			oCenterLine1 = oSketch.AddByProjectingEntity(oCenterline)
	Next
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oStartPoint As Point2d = oTG.CreatePoint2d(oCenterLine1.Geometry.StartPoint.X - 1, oCenterLine1.Geometry.StartPoint.Y + 1)
    Dim oEndPoint As Point2d = oTG.CreatePoint2d(oCenterLine1.Geometry.EndPoint.X+1, oCenterLine1.Geometry.EndPoint.Y+1)
	Dim oSectionLine1 As SketchLine = oSketch.SketchLines.AddByTwoPoints(oStartPoint,oEndPoint)
	Dim oDimension1 As DimensionConstraint = oSketch.DimensionConstraints.AddTwoPointDistance _
											(oSectionLine1.StartSketchPoint, oCenterLine1.StartSketchPoint, _
											DimensionOrientationEnum.kVerticalDim, oSectionLine1.Geometry.MidPoint)
	Dim oDimension2 As DimensionConstraint = oSketch.DimensionConstraints.AddTwoPointDistance _
											DimensionOrientationEnum.kHorizontalDim, oCenterLine1.Geometry.StartPoint)
	Dim oDimension3 As DimensionConstraint = oSketch.DimensionConstraints.AddTwoPointDistance _
											(oSectionLine1.EndSketchPoint, oCenterLine1.EndSketchPoint, _
											DimensionOrientationEnum.kHorizontalDim,oCenterLine1.Geometry.EndPoint)
    oSketch.ExitEdit
	Dim oInsertionPoint As Point2d = oTG.CreatePoint2d((oFirst_view.Position.X + 10), (oFirst_view.Position.Y + 10))
	Dim oSectionView As SectionDrawingView = oSheet.DrawingViews.AddSectionView _
											(oFirst_view, oSketch, oInsertionPoint, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
	oSectionView.SetDesignViewRepresentation(oSectionView.DesignViewRepresentation, True)
	oSectionView.ReverseDirection
	oSectionView.SectionDepth = 50/10
End Sub
Regards
Alan
Message 23 of 32
malmal02122023
Thank you very much. Is it possible to select by message box the section depth with offsets from work plane?
In this case there is expression for depth =50/10  offset is 50 mm and scale 1:10.
Message 24 of 32
malmal02122023
Could you answer for another question?
Is it possible to select several work planes at a time by input list box and create several separate sections. For example, select work planes 1, 2, 4, 7 and create separate horizontal sections for them with the selected offset and depth.
Thanks again.
Message 25 of 32
A.Acheson
Hi @malmal02122023
If your looking to make universal version of your code to adjust to any workplane regardless of orientation vertical /horizontal this would be possible but would be definitely more involved. You would need to adjust your code to include x and y offsets automatically.
Having said that I tried working with
DrawingSketch.OffsetSketchEntitiesUsingDistance Method
and this allowed an offset line parralel to the centerline with minimal input to change direction other than to specify true / false. The only down side was the offset line was exactly the same length as the centerline which made dimesioning a challenge.
Regards
Alan
Message 26 of 32
malmal02122023
It would be great to have it in two axes x and y
Message 27 of 32
malmal02122023
But I'll have enough horizontal sections for now.
Just a question
Is it possible to make them by selecting several different working planes at the time?
Message 28 of 32
A.Acheson
The rule is currently set up to select only one plane and section. If you want more planes sectioned then run again or start making sub routines and supply the workplace selected as an argument.
Regards
Alan
Message 29 of 32
malmal02122023
Well then, how can I call up the window for setting the depth of the section and its offset?
Message 30 of 32
A.Acheson
I believe your depth is already been set after the view is created via
You just need an input box if you want the user to customize it. Offset the value is hardcoded as 1cm again you just need to drive that value by inputbox. If you want a better way to do this then a win form would be the best. I would think that is more for streamlining at the end of your project.
Regards
Alan
Message 31 of 32
malmal02122023
Message 32 of 32
malmal02122023
And if a visible plane XZ should be added to the new section view then it has to looked like this:
oWp = oSkeletonDoc.ComponentDefinition.Item("XZ Plane")
    'Create proxy object
    Dim oWPpx As WorkPlaneProxy
    Call oOcc.CreateGeometryProxy(oWp, oWPpx)
    'Set visibility
         	oSectionView.SetIncludeStatus(oWPpx, True)
	oSectionView.SetVisibility(oWPpx, True)
Best regards
