Drawing list
Drawing list
johan.degreef
Advisor Advisor
Drawing list
johan.degreef
We have our titleblocks & partlists filled in by the models (parts & &assemblies) custom iproperties. All our dwg's are in the root of the project folder, +-30-40 dwg's
It would be handy If you have an updated drawinglist (heading with projectnumber, projecttitle, client,...) table with a drawing per line (Drawingnumber, drawingtitle, revision, paperformat,...)
You know if something similar if already shared here?
Many Thanks, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
yan.gauthier
How are you planning to do that ? from Excel ? using VBA ? or VBA writting to an excel file ?
iProperties can be accessed without opening files so it can be done without too much problems
johan.degreef
Yes, the idea was to export it to an excel.
yan.gauthier
In that case, you could use InventorApprentice Object from excel to get iProperties values from drawings.
Or you could create an Excel object from inventor and write your properties to excel. Are you familiar with VBA ? I don't believe there is a solution for your exact need you could just copy.
