Drawing label for custom design tracking Iproperty
josh.linares-stanley
I have the following ilogic script that formats flat pattern views. It does work, However i'd prefer for the "Thickness" to be custom design tracking property like the other iproperties that are in 'grey'. oGauge seems to just quote the current value instead of tie the text to the true value of the model.
doc = ThisDoc.Document
For Each oSheet In doc.Sheets
  For Each oView In oSheet.DrawingViews
    If oView.IsFlatPatternView Then
        'capture the current view label
                ViewLabel = oView.name
			'clear current view label
				oView.Label.FormattedText = ""
                oModelName = _
                oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
                Try
					oMaterial = "<StyleOverride Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
           			oGauge = iProperties.Value(oModelName, "Custom", "Thickness")
					oDescription = "<StyleOverride Underline='false'> - <Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
					oPartNumber = "<StyleOverride Underline='false'><Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
					oStringScale = "<Br/><StyleOverride FontSize='0.25'>(SCALE <DrawingViewScale/>)</StyleOverride>"
							            'add the the iProperty to the current view label, with a dash separator
                oView.Label.FormattedText = oPartNumber & oDescription & "<Br/>CONSTRUCTED FROM " & oGauge & " THK " & oMaterial & oStringScale & "<Br/>FLAT PATTERN"
            Catch
            'do nothing if error
                End Try
  Next
Next
JelteDeJong
As far as I know, there is no property for the thickness that you can use. But you could change the line:
to:
oGauge = Parameter(oModelName, "Thickness")
The parameter "Thickness" is always up to date. (The iProperty Thickness is not updated automatically by default) Then if the rule works you could add it to the event trigger "Before save document". then you know when you save the drawing the view labels get updated.
Jelte de Jong
Blog: hjalte.nl - github.com
