Drawing drop down list
Hi there,
I am creating a new template for my company and would like to include a drop-down list in the title block so that I may choose between material types on each sheet.
I am using the drawings for creating a laminating book and, therefore, cannot use the model material iProperty.
I would appreciate if you could help me.
mdavis22569
That' might need to be a prompted or linked to excel type of Text in the Title Block
Can you share a few examples or screenshots of what you're like to look like when done.
Might be something done with iLogic that when you create it, the iLogic as your list of options built into it.
Or it could be iLogic to populate it
Mike Davis
I attached an example of what I would like it to look like.
I just want to be able to input all the materials I will need along the manufacture process for then choosing an item of the material list for each sheet.
Thank you!
mdavis22569
Me I'd look at iLogic  / VBA options.
I don't think it's going to be anything out of the box / simple.
Mike Davis
lena.talkhina
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
