Drawing creation for each Part
richie_tony007
richie_tony007
Hi All,
I want to create two views for each part in this code but i dont know how to use document as a component occurences
Sub main
	Dim modelReference As Document = ThisApplication.ActiveDocument
	CreateSheet()
	ShowPanelParts(modelReference)
End Sub
Sub CreateSheet
	' Set the path to the template file
	Dim templatePath As String = "C:\_VaultPro\Templates\MKT DESIGN TEMPLATE.dwg"
	Dim oDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templatePath)
	Dim oSheet As Sheet = oDoc.Sheets(1)
	' Display message
	MessageBox.Show("Drawing created successfully from the template!")
End Sub
Sub ShowPanelParts(modelReference As Document)
    ' Check if the document is an assembly
    If modelReference.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        ' Get the assembly document
        Dim oAsmDoc As AssemblyDocument = modelReference
        ' Create a collection to store unique part names (without "LEFT" or "RIGHT")
        Dim uniqueParts As New Collection()
        ' Loop through all the components in the assembly
        For Each oComp As ComponentOccurrence In oAsmDoc.ComponentDefinition.Occurrences
            ' Skip suppressed parts
            If oComp.Suppressed = False Then
                ' Check if the component name contains "PANEL" (case-sensitive, all uppercase)
                If InStr(oComp.Name, "PANEL") > 0 Then
                    ' Remove "LEFT" and "RIGHT" from the name to treat them as one part
                    Dim partName As String = oComp.Name.ToUpper()
                    ' Remove "LEFT" or "RIGHT" from the name
                    partName = Replace(partName, " LEFT", "")
                    partName = Replace(partName, " RIGHT", "")
                    ' Check if the part name already exists in the unique parts collection
                    Dim isDuplicate As Boolean = False
                    For Each uniquePart As String In uniqueParts
                        If uniquePart = partName Then
                            isDuplicate = True
                            Exit For
                    Next
                    ' If it's not a duplicate, add it to the collection and show the message
                    If Not isDuplicate Then
                        uniqueParts.Add(partName)
'						CreateViews(oComp)
                        MessageBox.Show("Found part: " & oComp.Name)
						CreateViews(oComp)
        Next
    Else
        MessageBox.Show("The active document is not an assembly.")
End Sub
'*** Define Scale
Sub CreateViews(oComp As ComponentOccurrence)
	' Scale for the views
    Dim scale As Double = 1 / 3
    ' Get Active Drawing Sheet
    Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
    Dim oSheet As Sheet = oDoc.ActiveSheet
    DeleteAllViews(oSheet)
    ' Define View Locations
    Dim sheetCenterVertical As Double = (oSheet.Height / 2)
    Dim isoViewHorizontal As Double = (oSheet.Width * 0.25)
    Dim frontViewHorizontal As Double = (oSheet.Width * 0.75)
    ' Create Points for View Locations
    Dim oIsoViewPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(isoViewHorizontal, sheetCenterVertical)
    Dim oFrontViewPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(frontViewHorizontal, sheetCenterVertical)
    ' Define View Orientation
    Dim isoViewOrientation As ViewOrientationTypeEnum = kIsoTopRightViewOrientation
    Dim frontViewOrientation As ViewOrientationTypeEnum = kFrontViewOrientation
    ' Define View Style
    Dim isoViewStyle As DrawingViewStyleEnum = kShadedDrawingViewStyle
    Dim frontViewStyle As DrawingViewStyleEnum = kHiddenLineRemovedDrawingViewStyle
    ' Create the Views for the specific panel part
    Dim oIsoView As DrawingView = oSheet.DrawingViews.AddBaseView(oComp, oIsoViewPoint, scale, isoViewOrientation, isoViewStyle)
    oIsoView.Name = oComp.Name & " ISOMETRIC VIEW"
    Dim oFrontView As DrawingView = oSheet.DrawingViews.AddBaseView(oComp, oFrontViewPoint, scale, frontViewOrientation, frontViewStyle)
    oFrontView.Name = oComp.Name & " FRONT VIEW"
End Sub
'*** Function To Delete All Views
Sub DeleteAllViews(oSheet As Sheet)
	Dim oView As DrawingView
	For Each oView In oSheet.DrawingViews
		oView.Delete()
	Next
End Sub
Can any one help please
Ivan_Sinicyn
Try this^
Sub Main
    ' Get the active document (must be an assembly)
    ' Check if the active document is an assembly
    If modelReference.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        MessageBox.Show("The active document must be an assembly.")
        Exit Sub
    ' Create a new drawing
    Dim oDrawingDoc As DrawingDocument = CreateSheet()
    ' Check if the drawing was created successfully
    If oDrawingDoc Is Nothing Then
        MessageBox.Show("Failed to create the drawing. Rule execution aborted.")
        Exit Sub
    ' Pass the model and drawing to create views
    ShowPanelParts(modelReference, oDrawingDoc)
End Sub
Function CreateSheet() As DrawingDocument
    ' Specify the path to the template file
    ' Check if the template file exists
    If Not System.IO.File.Exists(templatePath) Then
        MessageBox.Show("Error: Template file '" & templatePath & "' not found. Ensure the path is correct and the file is accessible.")
        Return Nothing
    ' Try to create a new drawing based on the template
    Try
        ' Activate the first sheet
        Dim oSheet As Sheet = oDoc.Sheets.Item(1)
        ' Notify about successful drawing creation
        MessageBox.Show("Drawing successfully created from the template!")
        ' Return the created drawing
        Return oDoc
    Catch ex As Exception
        MessageBox.Show("Error creating drawing: " & ex.Message)
        Return Nothing
    End Try
End Function
Sub ShowPanelParts(modelReference As Document, oDrawingDoc As DrawingDocument)
        ' Get the active sheet of the drawing
        Dim oSheet As Sheet = oDrawingDoc.ActiveSheet
        ' Create a collection for unique part names
        ' Loop through all components in the assembly
                    ' Check if the part is already in the collection
                            isDuplicate = True
                            Exit For
                    Next
                    ' If the part is unique, add it and create views
                        CreateViews(oComp, oSheet)
        Next
    Else
        MessageBox.Show("The provided document is not an assembly.")
End Sub
Sub CreateViews(oComp As ComponentOccurrence, oSheet As Sheet)
    ' Set the scale for the views
    ' Define the view locations on the sheet
    ' Create points for view placement
    ' Define view orientations
    ' Define view styles
    ' Create views for the component
    Try
        Dim oIsoView As DrawingView = oSheet.DrawingViews.AddBaseView(oComp.Definition.Document, oIsoViewPoint, scale, isoViewOrientation, isoViewStyle)
        Dim oFrontView As DrawingView = oSheet.DrawingViews.AddBaseView(oComp.Definition.Document, oFrontViewPoint, scale, frontViewOrientation, frontViewStyle)
        MessageBox.Show("Error creating views for part '" & oComp.Name & "': " & ex.Message)
    End Try
End Sub
If you want to create views for each part on a separate sheet, you will need to add the creation of a new sheet within the loop in ShowPanelParts using oDrawingDoc.Sheets.Add() and pass the new sheet to CreateViews.
INV 2026.4
richie_tony007
Thanks for your reply. @Ivan_Sinicyn
It works but the newly created sheet doesnt have a title block and the sheet sizes are different from the 1st sheet.i want the same title block and sheet sizes which i used for sheet 1
Ivan_Sinicyn
You can use the first drawing sheet as a template and delete it at the end of the operation.
Sub Main
        Exit Sub
        Exit Sub
End Sub
        Return Nothing
    Try
        Return oDoc
        Return Nothing
    End Try
End Function
        ' Get the first sheet from the template to use as a base
        Dim oBaseSheet As Sheet = oDrawingDoc.Sheets.Item(1)
        ' Counter for sheet naming
        Dim sheetCounter As Integer = 1
                            isDuplicate = True
                            Exit For
                    Next
                    ' If the part is unique, add it and create views on a copied sheet
                        ' Copy the base sheet
                        Dim oNewSheet As Sheet = oBaseSheet.CopyTo(oDrawingDoc)
                        oNewSheet.Name = "Sheet " & sheetCounter & " - " & oComp.Name
                        sheetCounter = sheetCounter + 1
                        ' Create views on the copied sheet
                        CreateViews(oComp, oNewSheet)
                        MessageBox.Show("Found part: " & oComp.Name & " - Views created on " & oNewSheet.Name)
        Next
        ' Delete the original first sheet after all operations
        If oDrawingDoc.Sheets.Count > 1 Then
            oBaseSheet.Delete()
            ' Activate the first remaining sheet
            oDrawingDoc.Sheets.Item(1).Activate()
    Else
End Sub
    Try
    End Try
End Sub
INV 2026.4
BM_Ashraf
If you need a ready to use Add-in without complex Coding, check ADC (Automatic Drawing Creator)
https://bluemech.de/product/inventor-adc-automatic-drawing-creator/
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
richie_tony007
Thanks Heaps @Ivan_Sinicyn That works but i have modified my code to add the iso full assembly on the first page followed by the parts list and the part drawings
how to add the template for partslist and keep the iso full assembly view only on the 1st sheet.
Sub Main()
	Exit Sub
	Exit Sub
' Pass the model and drawing to create views and the parts list
ShowAssemblyViews(modelReference, oDrawingDoc)
End Sub
		Return Nothing
	Try
		Return oDoc
		Return Nothing
	End Try
End Function
Sub ShowAssemblyViews(modelReference As Document, oDrawingDoc As DrawingDocument)
		' Get the first sheet (to place the assembly iso view)
		Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
		' Create the isometric view of the full assembly
		CreateAssemblyIsoView(oAsmDoc, oSheet)
		' Create parts list on the second sheet
		CreatePartsList(oAsmDoc, oDrawingDoc)
		' Create unique sheets for individual parts
		ShowPanelParts(oAsmDoc, oDrawingDoc)
	Else
End Sub
Sub CreateAssemblyIsoView(oAsmDoc As AssemblyDocument, oSheet As Sheet)
	' Set the scale for the assembly isometric view
	Dim scale As Double = 1 / 25
	' Define the view location on the sheet
	Dim isoViewVertical As Double = (oSheet.Height * 0.5)
	Dim oIsoViewPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(isoViewHorizontal, isoViewVertical)
	Try
		Dim oIsoView As DrawingView = oSheet.DrawingViews.AddBaseView(oAsmDoc, oIsoViewPoint, scale, isoViewOrientation, isoViewStyle)
		oIsoView.Name = "ASSEMBLY ISOMETRIC VIEW"
		MessageBox.Show("Error creating assembly isometric view: " & ex.Message)
	End Try
End Sub
Sub CreatePartsList(oAsmDoc As AssemblyDocument, oDrawingDoc As DrawingDocument)
	Try
		' Get the first drawing view on the first sheet (this should be the full assembly view)
		Dim oDrawingView As DrawingView = oSheet.DrawingViews.Item(1)
		' Define position for the parts list (on the second sheet)
		Dim oNewSheet As Sheet = oDrawingDoc.Sheets.Add()
		oNewSheet.Name = "Parts List"
		Dim oPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(10, oNewSheet.Height - 10)
		' Create the parts list (BOM) using the assembly drawing view
		Dim oPartsList As PartsList = oNewSheet.PartsLists.Add(oDrawingView, oPosition)
		' Auto arrange and renumber parts
		oPartsList.Renumber()
		' Set the parts list style (optional)
		oPartsList.Style = oDrawingDoc.StylesManager.PartsListStyles.Item("Default")
		MessageBox.Show("Parts list successfully created on the second sheet.")
		'        MessageBox.Show("Error creating parts list: " & ex.Message)
	End Try
End Sub
                            isDuplicate = True
                            Exit For
                    Next
        Next
'        If oDrawingDoc.Sheets.Count > 1 Then
'            oBaseSheet.Delete()
'            ' Activate the first remaining sheet
'            oDrawingDoc.Sheets.Item(1).Activate()
'        End If
    Else
End Sub
	' Set the scale for the views of individual parts
	Dim scale As Double = 1 / 12
	Dim rightViewHorizontal As Double = (oSheet.Width * 0.75)
	Dim oRightViewPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(rightViewHorizontal, sheetCenterVertical)
	Dim rightViewOrientation As ViewOrientationTypeEnum = kRightViewOrientation
	Dim rightViewStyle As DrawingViewStyleEnum = kHiddenLineRemovedDrawingViewStyle
	Try
		Dim oRightView As DrawingView = oSheet.DrawingViews.AddBaseView(oComp.Definition.Document, oRightViewPoint, scale, rightViewOrientation, rightViewStyle)
		oRightView.Name = oComp.Name & " RIGHT VIEW"
		'        MessageBox.Show("Error creating views for part '" & oComp.Name & "': " & ex.Message)
	End Try
End Sub
