Drag Drop for Inventor Addins
Dev_rim
Dev_rim
Hi everyone.
How can i create drag drop feature for an addin?
I have to use OnDrag, OnMouseMove, OnMouseUp events. How can i implement them in addin?
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
NachoShaw
drag drop for what exactrly? drag drop on a form into listbox, datagrid, textbox or drag drop into the design window?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Dev_rim
Converting the selected occurrence to graphic node and moving it on the plate. We use selectable nodes for this.
