Doesn't pick up virtual Parts
Fazlur_Rahaman
Message 1 of 11
Fazlur_Rahaman
Hi there,
Can someone look at my code below and able to tell me why it doesn't recognize the Virtual Part Numbers?
Dim oBOM As BOM = ThisAssembly.Document.ComponentDefinition.BOM
'Make sure the views are enabled
oBOM.StructuredViewEnabled = True
Dim MyArrayList As New ArrayList
MyArrayList = GoExcel.CellValues("C:\Users\XXXXX\Documents\Inventor iLogic External Rules\5066 Part Numbers.xlsx", "Sheet1", "A1","B2175")
oRowStart = 2 'first row check
oRowEnd = 2175 'lat row check
'get info from the XLS file
For MyRow = oRowStart To oRowEnd 'index row 2 through 200
'Primary Head
partNUMBER = GoExcel.CellValue("B" & MyRow)
itemNUMBER1 = GoExcel.CellValue("A" & MyRow)
For Each oBOMRow As BOMRow In oBOM.BOMViews.Item("Structured").BOMRows
If oBOMRow.ComponentDefinitions(1).Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value.Contains(partNUMBER) Then
	oBOMRow.ItemNumber = itemNUMBER1
Next
Next
Dim doc As Document = ThisDoc.Document
Dim partslist As PartsList
Dim aDoc As AssemblyDocument
If (doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject) Then
    Dim dDoc As DrawingDocument = ThisDoc.Document
    partslist = dDoc.ActiveSheet.PartsLists.Item(1)
    aDoc = partslist.ReferencedDocumentDescriptor.ReferencedDocument
Else If (doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
    aDoc = doc
Else
	Return
If (aDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject)
	Return
Dim BOM As BOM = aDoc.ComponentDefinition.BOM
Dim oBOMView As BOMView = BOM.BOMViews("Structured")
oBOMView.Sort("Item", True,)
oBOMView.Renumber(1, 1)
Accepted solutions (3)
Replies (10)
Message 2 of 11
A.Acheson
Hi @Fazlur_Rahaman
I suspect this is because the document attached to the component definition will be an assembly when filtering for partnumber iproperties, virtual parts do not have sn individual document outsidevof an assembly. Virtual parts have the property sets inside the component definition as they live only inside an assembly. See virtualcomponentdefinition help page here
Try this for virtual parts.
If oBOMRow.ComponentDefinitions(1).PropertySets.Item("Design Tracking Properties").Item("Part Number").Value.Contains(partNUMBER) Then
 I also notice you will not be able to get to nested virtual parts inside nested sub assemblies as the rule is not iterating through the children. See an example of BOM children iteration  in the API help here
Regards
Alan
Message 3 of 11
WCrihfield
Hi @Fazlur_Rahaman.  In addition to what @A.Acheson mentioned above, I see another place in your code (lines 6 & 7) that seems like it might not be right.  It looks like you are attempting to gather the values from a rectangular range of cells in Excel to a single ArrayList.  I do not think that works as intended.  Have you reviewed the contents of that ArrayList after that line of code in that iLogic rule, to see what it got?  You can normally only get multiple cell values of a single row or a single column.  The exception to that is when retrieving a named range from Excel using the IGoExcel.NamedRangeValue.  If the named range in Excel is a rectangular range containing multiple rows and multiple columns, you can receive a 2-dimensional Array of Object.  That is not a single list...it is more like multiple parallel lists, similar to how it was in Excel.
Edit:  After posting that, I looked closer, and it looks like you are not even using the data you retrieved in those two lines, and are just iterating through the Excel row directly after that.
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 11
Fazlur_Rahaman
Hi @A.Acheson , thank you for the suggestion. Can you reattach the link again? I am still a novice when it comes to coding.
I tried coping your code into mine, but keep getting following error Public member 'PropertySets' on type 'PartComponentDefinition' not found.
Hi @WCrihfield , the code does seem to work (except virtual component). The purpose is to iterate though the Excel rows and if matching Part number found, then assign 'Item Number' in the assembly.
The part numbers are listed in Excel column 'B' and Item number listed in Excel column 'A'. The code is to check the part number from excel against the Assembly BOM (Level one) and if match found, assign the corresponding Item number from Excel column A.
Message 5 of 11
A.Acheson
Regards
Alan
Message 6 of 11
A.Acheson
You will likely need a try catch or filter the component definition and then set the propertysets. Propertysets are not contained in part definition but are in virtual definition.
Regards
Alan
Message 7 of 11
Fazlur_Rahaman
Thank you for the suggestion @A.Acheson
I am able to manipulate the Item number of my virtual components. I am currently stuck at the part where i need to check if the Part number of this virtual component matches one of the rows in excel, you have any suggestion?
Here is my code:
MyArrayList = GoExcel.CellValues("C:\Users\fazlur.rahaman\Documents\Inventor iLogic External Rules\5066 Part Numbers.xlsx", "Sheet1", "A1", "B2176")
oRowEnd = 2176 'lat row check
For MyRow = oRowStart To oRowEnd 'index row 2 through XXXX
partNUMBER1 = GoExcel.CellValue("B" & MyRow)
Dim oAsm As AssemblyDocument
    Dim oBomRows As BOMRowsEnumerator
    Dim oBomRow As BOMRow
    Dim oBomView As BOMView
    Dim oDef As ComponentDefinition
    Dim ItemNumber As String
	Dim PartNumber As String
    oAsm = ThisDoc.Document
    oBOM = oAsm.ComponentDefinition.BOM
    oBOM.StructuredViewFirstLevelOnly = False
    oBomView = oBOM.BOMViews("Structured")
    oBomRows = oBomView.BOMRows
    For Each oBomRow In oBomRows
        oDef = oBomRow.ComponentDefinitions(1)
If TypeOf oDef Is VirtualComponentDefinition Then
 'NEED TO CHECK IF THE PART NUMBER OF THIS VIRTUAL COMPONENT MATCHES ONE OF THE ROWS IN EXCEL
			oBomRow.ItemNumber = itemNUMBER1
		Else If oDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value.Contains(partNUMBER1) Then
    Next
Next
Message 8 of 11
A.Acheson
Maybe something like this.
   If oDef.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = partNUMBER1 Then
     'DO SOMETHING
Regards
Alan
Message 9 of 11
Fazlur_Rahaman
Thank you for all your help again @A.Acheson. I got the code to work as expected. However i have run into another issue. I have some parts that have quantity of '0', this is from suppressing Model State assemblies. I know this issue of BOM quantity of '0' was fixed in the Inventor 2023, but my organization is using 2022 and will do so for another year. So the parts that have '0' quantity are throwing up errors, its throwing error on line 38 in my code, where defined:
Do you have any suggestion on how to solve this?
Here is the full code:
	'organize the inital BOM from 3000
	oBomView.Sort("Item", True,)
	oBomView.Renumber(3000, 1)
oRowEnd = 2176 'last row check
		Else If oDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value="" Then
				oBomRow.ItemNumber = 3100
    Next
Next
'sort and renumber
oBomView.Renumber(1, 1)
Message 10 of 11
WCrihfield
Try editing those first couple lines of your loop like the following:
	oDef = Nothing
	Try : oDef = oBomRow.ComponentDefinitions(1) : Catch : End Try
	If oDef Is Nothing Then Continue For
Wesley Crihfield
Message 11 of 11
Fazlur_Rahaman
That worked perfectly, thank you @WCrihfield  & @A.Acheson for all your help.
Here is the final working code if anyone interested.
	   oDef = Nothing
    Next
Next
'sort and renumber
