Does weldments work differently than regular assemblies?
I use the code below to loop through the occurrences of an assembly. I am beginning to conclude that a weldment works differently since this code errors at the "For Each" line.
Does anyone know anything about this, do I need to look for the weldment, and do something different....
Kurt
Public Sub LoopThruAllChildParts(InvAssmDoc As AssemblyDocument, oDocArray() As Document)
If InvAssmDoc.DocumentType <> kAssemblyDocumentObject Then Exit Sub
Dim oAssyCompDef As AssemblyComponentDefinition
Set oAssyCompDef = InvAssmDoc.ComponentDefinition
Dim oParentOccur As ComponentOccurrence
Dim oChildOccDoc As Document
Dim TempPartCount As Integer
MsgBox oAssyCompDef.Occurrences.Count
For Each oParentOccur In oAssyCompDef.Occurrences
If Not oParentOccur.ReferencedDocumentDescriptor.ReferenceMissing _
And Not oParentOccur.Suppressed And Not oParentOccur.ReferencedDocumentDescriptor.ReferenceSuppressed Then
'code entered here
Next
End Sub
Weldment documents have an additional occurrence
that is not visible to users. Some properties/methods on this occurrence return
a failure since it cannot be queried/edited like a regular occurrences. In most
cases, you would want to skip this occurrence.
    'Skip weld
occurrence
    If Not TypeOf oParentOccur.Definition Is
WeldsComponentDefinition Then
        If
_
Then
        'code entered
here
Next
Sanjay-
Thanks a bunch, I will try this tomorrow...
Kurt
