Does this code look correct?... Rename browser names to match file names
chris
Advisor Advisor
chris
I asked Chat GPT Plus to:
Here's the code:
' Get a reference to the active assembly document
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
' Loop through all components in the assembly
For Each oComp As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences
' Get the file name of the component
Dim sFileName As String = oComp.Definition.Document.FullFileName
' Extract the file name without extension
Dim sNameWithoutExt As String = System.IO.Path.GetFileNameWithoutExtension(sFileName)
' Rename the browser node to match the file name
oComp.Name = sNameWithoutExt
Next
I get this error when I try to run it, but I don't know what it means or what to fix/change
JelteDeJong
The bot forgot that you need to give unique names to all occurrences. If you use the filenames directly you get into trouble if you use the same file 2 times. The most simple method of making something unique is to add an incremental number. Something like this:
Dim i = 1000
    oComp.Name = sNameWithoutExt & ":" & i
    i = i + 1
Next
Jelte de Jong
Blog: hjalte.nl - github.com
WCrihfield
Another thing that comes to mind is that you can essentially 'reset' the component names to their default, which I believe is the file name, by simply setting the component's name to an empty String.  When you do that it will usually resume its default name (what it would have naturally been named when you first inserted it).  But beware, if any of the components are Suppressed, you will not be able to access some of its properties without throwing errors.  And accessing the 'Definition' of a component when it is suppressed will definitely throw an error.  So, you may want to enclose the code within the loop in a Try...Catch block, to help avoid the potential errors.  You may also try going through the ComponentOccurrence.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName, in an attempt to avoid that other potential error.  Just some thoughts.
But there is a simple user interface tool specifically for this task too.  It can be found in the Assemble tab > Productivity panel (may not be showing), in the drop-down list is a tool named 'Rename Browser Nodes'.  When you click on it, it gives you a few options for how to rename them, including 'Filename' & 'Default'.
Wesley Crihfield
(Not an Autodesk Employee)
GosponZ
Try this one
oDoc = ThisDoc.Document
oSheets = oDoc.Sheets
For Each oSheet In oSheets
oSheet.activate
oView = oSheet.DrawingViews.Item(1)
modelName = oView.ReferencedDocumentDescriptor.ReferencedDocument
oProp = modelName.PropertySets.Item("Design Tracking Properties")
'ocProp = modelName.PropertySets.Item("Inventor User Defined Properties") 'Custom property set
ActiveSheet.Sheet.Name = oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value '_
'& " " & "QTY"
Next
oSheets(1).activate
