Document type from drawing view1
nicolamora
nicolamora
I would like to know what document type from view1 in drawing. This to have a macro in a drawing environment that does different things based on the document type in view1.
If View1 is "{4D29B490-49B2-11D0-93C3-7E0706000000}"
Then
If View1 is {9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}
Then
Nicola
Sergio.D.Suárez
Hi, Here you have a VBA code that verifies the type of reference document of the drawing view
'VBA Code
Sub Check_Type() Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet Set oSheet = oDoc.ActiveSheet Dim oView As DrawingView Set oView = oSheet.DrawingViews.Item(1) 'Select View from Item Dim oViewModelDoc As Document Set oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument If oViewModelDoc.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then 'standard part : {4D29B490-49B2-11D0-93C3-7E0706000000} MsgBox "standard part" End If If oViewModelDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then 'sheet metal part : {9C464203-9BAE-11D3-8BAD-0060B0CE6BB4} MsgBox "sheet metal part" End If End Sub
I hope it is useful for you. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
