Document settings with rule (Form)
Message 1 of 18
I'm new in Inventor and I have one problem.
I want to set Default BOM Structure (Document Settings/Bill of Materials) in my own Form (with Rule) for active part/assembly.
This Form (Rule) will be in template.
Is there any simlple way to do this (picture is in attachment)?
Thanx!
Replies (17)
Message 2 of 18
matt_jlt
To do this with an iLogic form would require the following
Make a text parameter, then make it multi-value and duplicate the BOM Structure type options
Add this to the form (it should be a combo box)
You will then need a rule that reads the multi-value parameter chosen and changes the BOM Structure based on this. Rough example below.
Select Case MultiParamName
Case "Phantom"
ThisDocument.ComponentDefinition.BOMStructure = "Chosen BOM Structure Type Here"
Case "Purchased"
ThisDocument.ComponentDefinitino.BOMStructure = ""Chosen BOM Structure Type Here"
End Select
Regards, Matt
Message 3 of 18
first thank you for helping.
But if I use your code for Rule, I got this error (in attachment).
What can be wrong? (I want to change document setting for part in part mode, not in assembly)
Message 4 of 18
matt_jlt
Hi, the code I wrote previously was just an outline to get you going. The code wouldn't actually work. Sorry, i should have been more clear. Try the code below (this is just a portion of what you need to achieve)
' Change BOM Structure
Select Case MultiValueParam
Case "Phantom"
	ThisDoc.Document.ComponentDefinition.BOMStructure = "51971" ' Set to Phantom Structure
Case "Normal"
	' Centering plate is required
	ThisDoc.Document.ComponentDefinition.BOMStructure = "51970" ' Set to Normal Structure
End Select
 Regards, Matt.
Message 5 of 18
If I create rule with just
ThisDoc.Document.ComponentDefinition.BOMStructure="51971"' Set to Phantom Structure
works fine. But if I want to use this with multivalue parameter doesn't. (If I set parameter to normal/phantom, no rule is runing).
And where can I find numbers like 51971? Is there any list of them?
And one more question. Is there any way for reverse procedure - if I will choose BOM Structure in Document Settings, it will change in Parameter and Form too?
Message 6 of 18
matt_jlt
Did you create a multi value parameter? See image below for what you need.
Add the code below to an iLogic Rule. It should change the bom structure when you change the parameter.
' Get part component definition
Dim oCompDef As PartComponentDefinition = ThisDoc.Document.ComponentDefinition
' Change BOM Structure based on multi value parameter
' BOM Structure Enumerator values are available in the programming help menu in Inventor.
Select Case BOMStructureParam
Case "Normal"
	oCompDef.BOMStructure = "51970"
Case "Phantom"
	oCompDef.BOMStructure = "51971"
Case "Reference"
	oCompDef.BOMStructure = "51972"
Case "Purchased"
	oCompDef.BOMStructure = "51973"
Case "Inseparable"
	oCompDef.BOMStructure = "51974"
End Select
To change the BOM Structure to match what a user has selected use:
Select Case oCompDef.BOMStructure
Case "51970"
	BOMStructureParam = "Normal"
Case "51971"
	BOMStructureParam = "Phantom"
Case "51972"
	BOMStructureParam = "Reference"
Case "51973"
	BOMStructureParam = "Purchased"
Case "51974"
	BOMStructureParam = "Inseparable"
End Select
 You will have to get the order / events in which the rules are run correct for it to work properly but it should work.
Regards, Matt.
Message 7 of 18
Thank you!
It works perfekt!
Message 8 of 18
GosponZ
I did same, don't have error  but BomStructure in active part is not changed. Do i missed something in here?
Thank you
Message 9 of 18
Vladimir.Ananyev
Hi nicomajstr
BOM structure types are listed in BOMStructureEnum Enumerator (in the Inventor API Help).
Name
Value
Description
kDefaultBOMStructure
51969
The default structure type.
kInseparableBOMStructure
51974
The inseparable structure type.
kNormalBOMStructure
51970
The normal structure type.
kPhantomBOMStructure
51971
The phantom structure type.
kPurchasedBOMStructure
51973
The purchased structure type.
kReferenceBOMStructure
51972
The reference structure type.
kVariesBOMStructure
51975
The structure type varies amongst references.
That means you may use “BOMStructureEnum.kPhantomBOMStructure” instead of 51971.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 10 of 18
gordon.bowe
I have previously created a Form that collects all the iProperties that we should change in to one place, and I would like to add a combo box for setting the default BOM structure of the active part/assembly.
I have created two rules based on the above code from Matt.
First rule is SetBOM, and runs the first set of code to set the default BOM structure based on the parameter I created
Second rule is SetParam and that one sets the multi-value parameter to match the default BOM structure defined in the document properties.
The issue I am having is that somehow my parameter is "linking" to SetParam, so when i open the Form and change the value, it instantly changes back.
My intent was to have a button below the combo box labeled "APPLY" that would run SetBOM, and then use an iTrigger before save to run SetParam, however it seems that SetParam is running automatically.
is there a way to change this behavior?  Or maybe there is a way to "synchronize" the two without having to fiddle with two rules and iTriggers?
Message 11 of 18
WCrihfield
Are these rules you created "Local" rules or "External" rules?
One thing that comes to mind that sounds like what your experiencing, is that when you have a local rule (rule is only located within the document), and that rule has BLUE colored local Parameters within it, this causes the rule to run every time it senses the value of that local parameter has changed.  This may be what's going on with it automatically changing on you when you use the Form.
Wesley Crihfield
(Not an Autodesk Employee)
Message 12 of 18
gordon.bowe
They are local rules and that was in fact the issue.  I checked the box under options to stop the rule from running automatically, but I may look in to making the rules external in the future.
Using the above code samples mentioned and a user parameter, I am able to get the thing working, however this requires adding the parameter to existing parts.
I have found a few examples of "try - catch" statements to attempt setting a parameter and using the catch to create one if it does not exist, but for some reason it is not working for me.  The code runs thru and no parameter is created.  Maybe this is due to the rule being a local rule?
I can upload the files
Message 13 of 18
WCrihfield
If you want a somewhat simple rule to create a UserParameter and set its options you can use something like the following code.
Parameter.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
ups = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParamName = "CA"
Try
	'Checking to see if this Parameter already exists
	t = Parameter.Param(oParamName)
Catch
	'If this Parameter doesn't exist, create it
	oParameter = ups.AddByExpression(oParamName, 80 ,"in")
	cl = Parameter.Param(oParamName)
	cl.Comment = "This Parameter was created from an iLogic Rule."
	cl.IsKey = True
	cl.ExposedAsProperty = True
	upcpf = cl.CustomPropertyFormat
	upcpf.PropertyType = Inventor.CustomPropertyTypeEnum.kNumberPropertyType
	upcpf.Units = Inventor.UnitsTypeEnum.kInchLengthUnits
	upcpf.Precision = Inventor.CustomPropertyPrecisionEnum.kEightDecimalPlacesPrecision
End Try
'Output Parameters values from this rule to the Model. (Use this before Document Update)
RuleParametersOutput()
'Immediately update the current document.
InventorVb.DocumentUpdate()
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution'.
Or if this helps you along the way to solving your problem, please click 'Like'.
Wesley Crihfield
Message 14 of 18
gordon.bowe
Thank you so much, this works perfectly.
I have one final hurdle to overcome.
In my "local rule" version, i have separated the definitions as follows:
For Assembly documents i have:
Dim oCompDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
' Set BOM Structure iProperty for use with Vault Select Case oCompDef.BOMStructure Case "51970" BOM_MStr = "Normal" iProperties.Value("Custom", "BOM Structure") = "Normal" Case "51971" BOM_MStr = "Phantom" iProperties.Value("Custom", "BOM Structure") = "Phantom" Case "51972" BOM_MStr = "Reference" iProperties.Value("Custom", "BOM Structure") = "Reference" Case "51973" BOM_MStr = "Purchased" iProperties.Value("Custom", "BOM Structure") = "Purchased" Case "51974" BOM_MStr = "Inseparable" iProperties.Value("Custom", "BOM Structure") = "Inseparable" End Select
and for part documents i have:
If i am going to combine these two in an external rule, I think i need to check if the open document is a part or assembly, and then set  oCompDef accordingly.
i tried a few things like:
Dim oDoc As Document = ThisApplication.ActiveDocument
'... Misc code here
If oDoc.DocumentType = kPartDocumentObject Then
  Dim oCompDef As PartComponentDefinition oCompDef = ThisDoc.Document.ComponentDefinition Else If oDoc.DocumentType = kAssemblyDocumentObject Then
Dim oCompDef As AssemblyComponentDefinition oCompDef = ThisDoc.Document.ComponentDefinition
however i get errors that oCompDef is not defined.   So i suppose you cannot define a variable within an "if - then" block?
full ***Non-Working*** code here:
'Rule will set the Default BOM structure of the document to match the user parameter BOM_MStr
'If the parameter does not exist, it will be created.
oParamName = "BOM_MStr"
Try
Catch
	oParameter = ups.AddByValue(oParamName, "Normal", UnitsTypeEnum.kTextUnits)
	MultiValue.SetList("BOM_MStr", "Normal", "Phantom", "Purchased", "Reference", "Inseperable")
End Try
Select Case BOM_MStr
	Case "Normal"
	Case "Phantom"
	Case "Reference"
	Case "Purchased"
	Case "Inseparable"
End Select
 the end goal is to get a form that collects all the iProperties we have to change constantly in to one place.
The button "Apply BOM Changes" will run a rule based on the code I referenced in the "accepted solution".
Message 15 of 18
WCrihfield
OK.  Try this.
oDoc = ThisDoc.Document
Dim oPdoc As PartDocument
oPdoc = ThisDoc.Document
Dim oPrtCompDef As PartComponentDefinition
Dim oAdoc As AssemblyDocument
oAdoc = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition
Dim oParams As Parameters
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
	oPrtCompDef = oPdoc.ComponentDefinition
	oParams = oPrtCompDef.Parameters
ElseIf oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oAsmCompDef = oAdoc.ComponentDefinition
	oParams = oAsmCompDef.Parameters
Else
	MessageBox.Show("This rule [ " & iLogicVb.RuleName & " ] only works on either Part Documents or Assembly Documents.", "WRONG DOCUMENT TYPE")
	Return
Dim oUParams As UserParameters
oUParams = oParams.UserParameters
Dim oUParam As UserParameter
Dim oParamName As String
Dim oItExists As Boolean
oItExists = False
For Each oUParam In oUParams
	If oUParam.Name = oParamName Then
		oItExists = True
Next
If oItExists = False Then
	'The specified Parameter doesn't exist, so create it, sets its value(s) & options.
	oParameter = oUParams.AddByValue(oParamName, "Normal", UnitsTypeEnum.kTextUnits)
ElseIf oItExists = True Then
		If Parameter(oParamName) = "Normal" Then
			oPrtCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure
		ElseIf Parameter(oParamName) = "Phantom" Then
			oPrtCompDef.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
		ElseIf Parameter(oParamName) = "Reference" Then
			oPrtCompDef.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
		ElseIf Parameter(oParamName) = "Purchased" Then
			oPrtCompDef.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
		ElseIf Parameter(oParamName) = "Inseperable" Then
			oPrtCompDef.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
			oAsmCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure
			oAsmCompDef.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
			oAsmCompDef.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
			oAsmCompDef.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
			oAsmCompDef.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
It may be a bit lengthy, and perhaps not the most efficient, but I think it will get the job done.
You probably already know this, but when you move your iLogic code from a 'Local' rule to an 'External' rule, you have to call out the Parameters differntly for them to continue to work properly.  That's why I used Parameter(oParamName) instead of just BOM_MStr.
Also, another coder on this Forum informed me that a For Each...Next loop statement actually uses less processing resources than a Try...Catch statement, so I changed the portion where it is looking for the Parameter to use this method instead.
You probably noticed that I changed the Select Case section to a If...Then section too.  This is somewhat of a personal preference on my part, because for some odd reason, I seem to have fewer errors down the road using this style.
I hope this helps.
If this helps, please click 'Like'.
Wesley Crihfield
Message 16 of 18
gordon.bowe
I hope this helps.
I had no idea, that is good to know.
Also I had heard the same thing about Try-Catch and thought about re-writing it, but decided to at least get the core code working first.
incidentally, your rule isnt working for me either.  It gives no errors or warnings, but i am getting an error when running it.
the first thing was that inventor did not like your message box.  RuleName is not a member of 'Autodesk.iLogic.Interfaces.ILowLevelSupport'.
But deleting that part let it compile.
then i got this error on run
I tried reorganizing the program to make it easier to troubleshoot, but that did not help
Sub Main()
	'Check for Parameter "BOM_MStr"
	CheckParameter()
	SetBOM()
End Sub
Function CheckParameter()
	Dim oUParams As UserParameters = oParams.UserParameters
	Dim oParamName As String = "BOM_MStr"
	Dim oItExists As Boolean = False
			oItExists = True
	Next
		'do nothing
End Function
Function SetBOM()
	Dim oDoc As Document = ThisDoc.Document
	Dim oPdoc As PartDocument = ThisDoc.Document
	Dim oAdoc As AssemblyDocument = ThisDoc.Document
	Else
		MessageBox.Show("This rule only works on either Part Documents or Assembly Documents.", "WRONG DOCUMENT TYPE")
		Return False
End Function
on my re-organized version, i get an error as well that object reference is not set to an instance of an object.
I am starting to feel that I may be asking too much of inventor / my programming skills.
Message 17 of 18
WCrihfield
This certainly seems possible, so I think that if not either of us, then someone else will fix this code to work right for you.
FYI:  One other thing that might help you along the way though.  Your ealier assumption was pretty much correct.
You can't 'define' (exe. Dim oCompDef As PartComponentDefinition) an Object or Variable within a Try...Catch statement, or within an If...Then statement, then use that Object or Variable  properly later, outside of that statement.
Wesley Crihfield
Message 18 of 18
gordon.bowe
I will give it some time for other people to take a look, but if I don't hear anything after some time, I can at least always fall back to having a local rule and one version for parts and one version for assemblies.
Remember that I had the thing working fine, and only needed to add a new parameter if it did not exist already.
We have figured out how to accomplish that, so I can add that code and move on.
