Dockable window with user control is not catching enter key press?
Jef_E
Message 1 of 21
Jef_E
I made a dockablewindow with a user control added as child control.
       ' Set reference to the user interface manager
        Dim oUserInterfaceMgr As UserInterfaceManager _
            = _InvApp.UserInterfaceManager
        ' Create a new dockable window
        _Browser = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "DDCIntName", "Ellimetal DDC")
        ' Add control to the dockable window
        _Browser.AddChild(Me.Handle)
        ' Dock the window to the right
        _Browser.DockingState = DockingStateEnum.kDockRight
        ' Show the title bar
        _Browser.ShowTitleBar = True
        ' Set the dockable window visible
        _Browser.Visible = True
        ' Set the window width
        _Browser.Width = 220
On this user control there is a textbox that is referenced with a constraint value. I would like to catch a keydown event for this textbox but it is not letting me for the ENTER key only. All other keys work. Is the dockable window catching my Enter keydown ? How can I tell if this is the problem? Can I do something about this?
    Private Sub tbOccurrenceElevation_KeyDown(sender As Object, e As KeyEventArgs) Handles tbOccurrenceElevation.KeyDown
        ' Check if the enter key is pressed
        If e.KeyCode = Keys.Return Then
            OccurrenceElevation_Changed()
    End Sub
I asked around on StackOverflow, maybe it was something with my vb.net code but apparently not. See link below
http://stackoverflow.com/questions/43119166/catch-if-user-presses-enter-key-in-textbox?noredirect=1#...
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (20)
Message 21 of 21
HideoYamada
I'm sorry for the time it took to reply.
The following code is working, but I believe there is a better way to resolve this issue...
This code runs properly only when MyNumericUpDown is used in one WinForm.
If you want to use this in multiple dockable window, the class must be created for the each window.
(e.g. class MyNumericUpDown1, class MyNumericUpDown2, ...)
class MyNumericUpDown : System.Windows.Forms.NumericUpDown
    #region Win32 API declare
    private static class NativeMethods
        [System.Runtime.InteropServices.DllImport("user32.dll", SetLastError = true)]
        internal static extern System.IntPtr SetWindowsHookEx(int hookType, HookObject.HookHandler hookDelegate, System.IntPtr module, uint threadId);
        internal static extern bool UnhookWindowsHookEx(System.IntPtr hook);
        [System.Runtime.InteropServices.DllImport("user32.dll")]
        internal static extern int CallNextHookEx(System.IntPtr hook, int code, System.IntPtr wParam, System.IntPtr lParam);
        [System.Runtime.InteropServices.DllImport("kernel32.dll")]
        internal static extern uint GetCurrentThreadId();
        internal static extern System.IntPtr GetFocus();
        [System.Runtime.InteropServices.DllImport("user32.dll", CharSet = System.Runtime.InteropServices.CharSet.Auto)]
        internal static extern System.IntPtr SendMessage(System.IntPtr hWnd, int Msg, System.IntPtr wParam, System.IntPtr lParam);
    private const int WH_KEYBOARD = 2;
    private const int VK_CANCEL = 0x03;
    private const int VK_RETURN = 0x0d;
    private const int VK_ESCAPE = 0x1b;
    #endregion
    #region Key Hook
    private class HookObject
        public delegate int HookHandler(int code, System.IntPtr wParam, System.IntPtr lParam);
        public HookHandler hookDelegate;
        public System.IntPtr hook;
        public void SetHook(HookHandler onHook)
            // Check this cotrol is in Visual Studio.
            bool inDesignMode;
            if (System.ComponentModel.LicenseManager.UsageMode == System.ComponentModel.LicenseUsageMode.Designtime)
                inDesignMode = true;
            else
                using (var p = System.Diagnostics.Process.GetCurrentProcess())
                    inDesignMode = (
                        p.ProcessName.Equals("DEVENV", System.StringComparison.OrdinalIgnoreCase) ||
                        p.ProcessName.Equals("XDesProc", System.StringComparison.OrdinalIgnoreCase)
            // Exexute only outside of Visual Studio.
            if (!inDesignMode)
                if (hook == System.IntPtr.Zero)
                    hookDelegate = new HookHandler(onHook);
                    hook = NativeMethods.SetWindowsHookEx(WH_KEYBOARD, hookDelegate, System.IntPtr.Zero, NativeMethods.GetCurrentThreadId());
                        int errorCode = System.Runtime.InteropServices.Marshal.GetLastWin32Error();
                        throw new System.ComponentModel.Win32Exception(errorCode);
        public void Unhook()
            if (hook != System.IntPtr.Zero)
                NativeMethods.UnhookWindowsHookEx(hook);
        public HookObject(HookHandler onHook)
            SetHook(onHook);
        ~HookObject()
            Unhook();
    private static readonly HookObject hookObject = new HookObject(OnHookKey);
    private static MyNumericUpDown focusedControl;
    private static int OnHookKey(int nCode, System.IntPtr wParam, System.IntPtr lParam)
        if (-1 < nCode)
            int vKey = (int)wParam;
            ulong keyFlag = (ulong)lParam;
            switch (vKey)
                case VK_RETURN:
                case VK_CANCEL:
                case VK_ESCAPE:
                    if ((keyFlag & 0xc0000000) == 0 && focusedControl != null)
                        focusedControl.ValidateEditText();
                        // If you want to fire other events, write the code here.
                        return 1;
                    break;
        return NativeMethods.CallNextHookEx(hookObject.hook, nCode, wParam, lParam);
    #endregion
    #region Event
    protected override void OnEnter(System.EventArgs e)
        base.OnEnter(e);
        focusedControl = this;
    protected override void OnLeave(System.EventArgs e)
        base.OnLeave(e);
        focusedControl = null;
    #endregion
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
