DoBoolean and splitting bodies
gilsdorf_e
gilsdorf_e
Hi all,
I'm using booleans for a custom method as alternative for findUsingRay and FindUsingVector, as those have isses with non-planar faces.
I wonder how TransientBRep.DoBoolean( BlankBody As SurfaceBody, ToolBody As SurfaceBody, BooleanType As BooleanTypeEnum )
behaves, when the blank body is split into two or more bodies by the toolbody. How can I test for this?
Best regards
Erik
adam.nagy
Autodesk Support
Autodesk Support
Hi Erik,
You can create TransientBReps from surfaces you created in the model, as shown here:
http://modthemachine.typepad.com/my_weblog/2013/07/inventor-2014-api-solid-imprinting.html
So just create the solids in the UI then use them to create the transient brep and do the boolean operation on them.
Cheers,
Adam Nagy
Autodesk Platform Services
