Do While statement case
danijel.radenkovic
danijel.radenkovic
I have a little problem to move from iLogic code to VBA code.
Here is the statement which I have to convert in VBA code:
If RealValue < TargetValue Then
	While RealValue < TargetValue
	pDistance = pDistance - .1
	RuleParametersOutput()
	InventorVb.DocumentUpdate(True)
	End While
ElseIf RealValue > TargetValue Then
	While RealValue > TargetValue
	pDistance = pDistance + .1
	End While
Any help is very appreciated.
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
NachoShaw
Hi
Based on your code, I would typically approach it this way however, I don't know what your code is doing or whether RealValue is updating during this particular code section. If its not, then it 'could' loop indefinitely as you are telling to continue in a loop until RealValue < TargetValue
Select Case RealValue
    Case < TargetValue
        Do While RealValue =< TargetValue
        Loop
    Case > TargetValue
        Do While RealValue >= TargetValue
        Loop
End Select
Hope that helps
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
danijel.radenkovic
@nmjshaw150 wrote:
Hi
    Case < TargetValue
        Loop
    Case > TargetValue
        Loop
End Select
Hope that helps
Nacho
Hi Nacho,
That is what I was trying to do. To convert vb.net statement to vba statement. In other words:
While
End While
'into:
Do While
Loop
Code between was not a problem. Differences between vb.net code and vba code can be a problem sometimes.
Thank you very much for the help!
Danijel
