Do prompted entry properties exist in Part or Assembly file? If exist then how can we get prompted entry properties of Part and Assembly file?
kawsar.cuetcse
kawsar.cuetcse
I have developed a tool by which we can get prompted entry property for drawing file(.idw and .dwg file).
Now, I am searching for prompted entry properties for part and assembly file. Do prompted entry properties exist in Part or Assembly file?
JelteDeJong
You could use the custom iProperties to act as "prompted entry properties". The rule below will check if a custom iProperty exists and is filled. if not it will ask for a value.
Dim promtedEntries As New List(Of String)
promtedEntries.Add("PromtedProperty1")
promtedEntries.Add("PromtedProperty2")
promtedEntries.Add("PromtedProperty3")
For Each entry As String In promtedEntries
	Try
		Dim entryValue As String = iProperties.Value("Custom", entry)
		If (String.IsNullOrEmpty(entryValue)) Then
			entryValue = InputBox(
				"Plz give value for: " + entry, "None value found")
			iProperties.Value("Custom", entry) = entryValue
	Catch ex As Exception
		Dim entryValue As String = InputBox(
	End Try
Next
Jelte de Jong
Blog: hjalte.nl - github.com
