Displaying a view into a PictureBox
Hi.
Is it possible to create a something like a snapshot or print screen of certain view using API and then displaying it into PictureBox control in a Visual Studio form? Something similar to what we can achieve using Client View through Apprentice Server but as far as I know this solution cannot be contained into an Inventor add-in and that's why I cannot use it in my project.
Is there any workaround in this situation? Getting a thumbnail image wouldn't be a good idea in this case so I am looking for another solution.
NachoShaw
hi
there isn't a method inside inventor. although the clientview requires an image of, it's not really an image. I did manage to make a workaround though in visual studio. it takes a bit of setting up but it's not that bad.
add a rectangle to the form at the same size and location as the picturebox.
use it as a snapshot frame and save the image out as a bitmap
I'll look tomorrow at my code projects, see if I can put the code up for you (was a while ago I did that)
thanks
nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
BrianEkins
You can do something as simple as what I've done below.  I created a new project and added a button (Button1) and a picture box (PictureBox1).  There's a reference to the Inventor interop and below is the code for the click event of the button.  It connects to Inventor, saves an image of the active few to a file, and then displays that image in the picture box.
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim invApp As Inventor.Application
        invApp = GetObject(, "Inventor.Application")
        Dim view As View = invApp.ActiveView
        view.SaveAsBitmap("C:\Temp\Junk.png", Me.PictureBox1.Width, Me.PictureBox1.Height)
        PictureBox1.Image = Image.FromFile("C:\Temp\Junk.png")
    End Sub
Brian Ekins
Thanks @BrianEkins and @NachoShaw for your contribution.
@BrianEkins your code is what I was looking for. I am very thankful for it.
@NachoShaw please post your code in this topic. I am very curious how your solution looks like. After that I will mark this topic as solved with two solutions.
