Display quantity in a drawing
Message 1 of 24
I would like to display the total quantity of each part of my project on its corresponding drawing. Is it possible in some way (using an iLogic rule?) to obtain the total number of a given part from the topmost assembly or BOM?
Thank you
Daniel
(Inventor 2016)
Replies (23)
Message 21 of 24
donaldleigh
thanks for the reply Adrian
I have been busy this week with other project and will check this out soon I hope
Donald
Message 22 of 24
AMISTRYZ5Q34
Hello
This code is helpful and I am thankful.
But if I am not wrong this code will help me generate a custom iProperty in each part when running it in the top-level assembly.
My problem is when we try to create the drawing Qty of the title block on the drawing it will not be updated directly
because the custom iProperty created by iLogic can not be linked to it.
Is there any way to link the custom Iproperty "Qty" to the title block Qty?
Thank you
Alay
Message 23 of 24
johnsonshiue
Hi Alay,
I believe so. As long as the custom property is defined in the drawing view model source component. It can be added to the Title Block. This should not require an iLogic rule.
Please feel free to share a template file you are working on. The forum experts can help take a look and propose a feasible solution.
Many thanks!
Software Test Engineer
Message 24 of 24
hamed_nemati
This is very good , But did'nt work when an assembly contain any subassembly
