Disconnected Referenced Files
I'm using the attached code to obtain a referenced document from Inventor's document cache. Sometimes it returns a document that seems to be disconnected from Inventor. Is there anyway to flush Inventor of all disconnected components without performing a close all? Or is there a clause I can add to my code that will ignore any disconnected parts? This is causing a problem because, when I try to use the returned disconnected document, my program throws an exception. So far, the only way I've found to overcome this issue is to close all documents.
Exception Message: The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
// Cycle through the Inventor application documents.
            foreach (Document _doc1 in from Document _doc1 in Application.Documents
                                       where _doc1.FileSaveCounter != 0
                                       where !string.IsNullOrEmpty(_doc1.FullFileName)
                                       where _doc1.FullFileName.Contains(_fullFileName)
                                       select _doc1)
                _docList.Add(_doc1);
                return _doc1;
adam.nagy
Autodesk Support
Autodesk Support
Hi Eric,
CloseAll has an option exactly for that - see help file or e.g. VBA Object Browser:
Documents.CloseAll( [UnreferencedOnly] As Boolean )
Cheers,
Adam Nagy
Autodesk Platform Services
