Dimentions
Dimentions
Dimentions
Any ideas/help please?
I have a problem with 2D dimensioning of diameters. Instead of the diameter symbol I get n as a prefix. This appears or I suspect is due to a setting on the model or template. I can’t work out what I need to change!!?? see attached as example.
Did you try searching?  Google
works...
And wrong newsgroup.  This is the
Customization (programming) newsgroup.
brian r.
iwaskewycz
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">inventor
specialist
style="FONT-SIZE: 14pt; FONT-FAMILY: Verdana">core furnace
systems
BTW, what are Dimentions anyway? My guess is demented dimensions 😉
Bob S.
brian r. iwaskewycz wrote:
> Did you try searching? Google works...
> http://www.google.com/search?hl=en&q=inventor+%22diameter+symbol%22+n&btnG=Google+Search&aq=f&oq
> And wrong newsgroup. This is the Customization (programming) newsgroup.
> *brian r. iwaskewycz*
> */inventor specialist/*
> *core furnace systems*
Thanks for the tip.
Sorry about the wrong group haven't used Discussion Groups for a while.
Well yes you do get a bit demented when trying to sort a problem.
