Dimensions in Triplicate
Message 1 of 8
Greetings,
The following is a code that works great for dimensioning.  The issue I am having is that when I align the dimensions, the code appears to have run three times.
This is what gets created.  (see screenshot below)
So I was wondering if someone can identify how or why the dimensions I want are being put on the drawing three times?
I found this code from someone on this forum  It is not my original.   I do know that it searches all parameters and looks for the prefix that I have identified.  I did figure out a way to simply delete the extra dimensions, however, it would be nice to prevent the deletion step.
SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oDrawView As DrawingView = oSheet.DrawingViews(1)
Dim oGeneralDimensionsEnum As GeneralDimensionsEnumerator
oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oDrawView)
Dim PrefixStr As String = "RDT_"
Dim oGeneralDimension As GeneralDimension
For Each oGeneralDimension In oGeneralDimensionsEnum
    Dim oParameter As Parameter
    oParameter = oGeneralDimension.RetrievedFrom.Parameter
    If oParameter.DrivenBy.count <> 0 Then
        Dim oDrivenByParameter As Parameter
        For Each oDrivenByParameter In oParameter.DrivenBy
            If InStr(oDrivenByParameter.Name, PrefixStr) = 0 Then
                oGeneralDimension.Delete
        Next
                Else
        If InStr(oParameter.Name, PrefixStr) = 0 Then
Next
Replies (7)
Message 2 of 8
wayne.brill
Please post the code that is creating the dimensions. The code provided seems like it is code that is just deleting dimensions.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
That is the code that creates the dimensions.  It retrieves the dimensions from the model.
Message 4 of 8
wayne.brill
I see what you mean now. I believe the problem you are seeing is that the .GeneralDimensions.Retrieve Method is creating too many dimensions.
I tried the code and I am not getting any duplicate dimensions in my tests. Please upload an assembly or part I can use to recreate this behavior.
Wayne
Wayne Brill
Message 5 of 8
Wayne,
Attached is the part file.
I thought maybe some how I have the dimensions created three times.  However, that is not the case.
Thanks for looking.
Message 6 of 8
wayne.brill
Thanks for uploading the ipt. I am able to recreate the behavior where each dimension comes in triplicate. Here is an aproach that only creates 8 dimensions instead of 24. Maybe this could be a work around.
' Dim oGeneralDimensionsEnum As GeneralDimensionsEnumerator
' oGeneralDimensionsEnum = oSheet.DrawingDimensions.GeneralDimensions.Retrieve(oDrawView)
Dim oDims As GeneralDimensions
oDims = oSheet.DrawingDimensions.GeneralDimensions
Dim oRetrievableDims As ObjectCollection
oRetrievableDims = oDims.GetRetrievableDimensions(oDrawView)
MessageBox.Show(oRetrievableDims.Count.ToString(), "Title")
Dim oDimsToRetrieve As ObjectCollection
oDimsToRetrieve = ThisApplication.TransientObjects.CreateObjectCollection
Dim obj As Object
For Each obj In oRetrievableDims
    oDimsToRetrieve.Add(obj)
Next
MessageBox.Show(oDimsToRetrieve.Count.ToString(), "Title")
If oDimsToRetrieve.Count > 0 Then
	oDims.Retrieve(oDrawView, oDimsToRetrieve)
Wayne
Wayne Brill
Message 7 of 8
Wayne,
When I run this code I have 11 dimensions appear.  How do I identify the 6 that I want to appear instead of all 11?  Can I add the find dim with the "prefix string" part into your code?
You code does take care of the triplicate piece so thank you for that. Just need to be able to isolate the 6 that I want.
Message 8 of 8
wayne.brill
I would use your code to delete the dimensions after they have been added. Here is what I tested with. With the ipt provided in a previous post I see five of the 8 dimensions getting deleted.
'MessageBox.Show(oRetrievableDims.Count.ToString(), "Title")
Dim obj As Object
Next
'MessageBox.Show(oDimsToRetrieve.Count.ToString(), "Title")
	oGeneralDimensionsEnum = oDims.Retrieve(oDrawView, oDimsToRetrieve)
 	'MessageBox.Show(oParameter.Value, "Title")
		'MessageBox.Show("Past oParameter.DrivenBy.count <> 0", "Title")
            'MessageBox.Show("Past For Each oDrivenByParameter", "Title")
				'This was never hit in my test - not sure if this For Each is needed
				MessageBox.Show("Deleted Dimension in For Each OParameter.DrivenBy loop", "Title")
        Next
                Else
			MessageBox.Show("Deleted Dimension in For Each oGeneralDimension loop", "Title")
Next
Wayne
Wayne Brill
