Dimensioning of the sketch points, imported from Excel onto the sketch surface of a rectangular sheet metal part using VBA.
hello,
I have actually written a code to import the points from the excel onto the sketch plane/planar surface of an inventor sheet metal part, which is working perfectly. But i am unable to auto-dimension those points as soon as they are imported on the sketch surface. The origin for dimensioning is to be taken as top left corner of the rectangular sketch surface.
Can anyone help me get the solution asap ?
Hi Vishal, I suggest that you post this on the Inventor Customisation forum (this is where you'll get help with programming and API related queries)
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Please mark this as solved to avoid a duplicate entry on the forums.
