Dimension using edge naming
nishantkumat5921
nishantkumat5921
I am trying to create dimensions using edge naming by assigning names to the edges manually and then identifying them and creating dimensions but i am getting an unspecified error in the general dimension creation line below is the code used
public static void Create_Linear_Dimensions_EntityNaming(Inventor.DrawingView CurrView, string PartNameWithoutExt, string OccNameInAssy, string EdgeName1, string EdgeName2, DimensionTypeEnum DimType, double DimGap, bool boolAssembly)
try
drawingDoc = (DrawingDocument)invApp.ActiveDocument;
Sheet oSheet = drawingDoc.ActiveSheet;
PartDocument oPartDoc = null;
Inventor.AssemblyDocument oAssyDoc = null;
Inventor.ComponentOccurrence CompOcc = null;
Inventor.Document CurrDocument =(Inventor.Document) CurrView.ReferencedDocumentDescriptor.ReferencedDocument;
if (CurrDocument.DocumentType == DocumentTypeEnum.kAssemblyDocumentObject)
oAssyDoc = (AssemblyDocument)CurrDocument;
DrgViewDocuments = new List<Inventor.Document>();
DrgViewCompOcc = new List<Inventor.ComponentOccurrence>();
GetAssyOccurences(oAssyDoc.ComponentDefinition.Occurrences, 0);
for (int i = 0; i <= DrgViewDocuments.Count - 1; i++)
CompOcc = DrgViewCompOcc[i];
Inventor.Document CurrDoc = DrgViewDocuments[i];
if ((System.IO.Path.GetFileNameWithoutExtension(CurrDoc.FullDocumentName).ToUpper() == (PartNameWithoutExt).ToUpper() && (CompOcc.Name).ToUpper() == (OccNameInAssy).ToUpper()))
oPartDoc = (PartDocument)CurrDoc;
break;
else if (CurrDocument.DocumentType == DocumentTypeEnum.kPartDocumentObject)
oPartDoc = (PartDocument)CurrDocument;
Edge Edge1, Edge2;
Inventor.ObjectCollection Obj1,Obj2;
Obj1 = invApp.TransientObjects.CreateObjectCollection();
Obj2 = invApp.TransientObjects.CreateObjectCollection();
Obj1 = oPartDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", EdgeName1);
//Edge1 = (Edge)Obj[1];
Obj2 = oPartDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", EdgeName2);
// Edge2 = (Edge)Obj[1];
Inventor.Point2d Point1, Point2;
double XPos, YPos;
DrawingCurvesEnumerator DrgCurveEnum;
DrawingCurve DrgCurve1 = null;
DrawingCurve DrgCurve2 = null;
object object1 = null, object2 = null;
EdgeProxy Edge1Proxy = null;
EdgeProxy Edge2Proxy = null;
try
if (boolAssembly == true)
CompOcc.CreateGeometryProxy(Obj1[1], out object1);
CompOcc.CreateGeometryProxy(Obj2[1], out object2);
Edge1Proxy = (EdgeProxy)object1;
Edge2Proxy = (EdgeProxy)object2;
else
DrgCurveEnum = CurrView.DrawingCurves[object1];
DrgCurve1 = DrgCurveEnum[1];
DrgCurveEnum = CurrView.DrawingCurves[object2];
DrgCurve2 = DrgCurveEnum[1];
} catch (Exception ex)
MessageBox.Show(ex.Message);
XPos = CurrView.Left + (CurrView.Width / 2); YPos = CurrView.Top;
Point2d point2D = invApp.TransientGeometry.CreatePoint2d(XPos, YPos);
GeneralDimensions oGeneralDims;
oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions;
GeneralDimension oDim;
oDim = (GeneralDimension)oGeneralDims.AddLinear(point2D, oSheet.CreateGeometryIntent(object1), oSheet.CreateGeometryIntent(object2), DimensionTypeEnum.kHorizontalDimensionType);//going to catch
catch (Exception ex) {
Ralf_Krieg
Hello
You try to create a linear dimension with two geometry intents of a drawingcurve. This works afaik only if both drawingcurves are linear, parallel to the other and vertical. In all other cases you have to specify a point on the drawing curve as intent or a second geometry intersecting the first.
R. Krieg
RKW Solutions
www.rkw-solutions.com
nishantkumat5921
Hi Krieg thanks for the quick solution but as mentioned above both the edges are linear and parallel to each other still i am facing the issue below is the image showing the edges.. The names are passed as arguments so ignore the code (EdgeName1)
Ralf_Krieg
Hello
No, you have not mentioned that the edges are linear, nor that they are parallel. Only that you start with named edges. 😉
Can you separate the creation of the both geometry intents and check if they are correct? You try to create geometry intents for object1 and object2, which are for a drawing view with a referenced part defined where?
I've tested the general functionality with a little VBA script. Works as expected. Maybe this can help you find a solution.
Public Sub CreateGeneralDimensions()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    Dim oDrawingView As DrawingView
    Set oDrawingView = oActiveSheet.DrawingViews.Item(1)
    Dim oRefedDoc As Document
    Set oRefedDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oDrawCurve1 As DrawingCurve
    Dim oDrawCurve2 As DrawingCurve
    Dim oObj1 As Object
    Dim oObj2 As Object
    Dim oObjColl1 As ObjectCollection
    Dim oObjColl2 As ObjectCollection
    Set oObjColl1 = ThisApplication.TransientObjects.CreateObjectCollection
    Set oObjColl2 = ThisApplication.TransientObjects.CreateObjectCollection
    If oRefedDoc.DocumentType = kAssemblyDocumentObject Then
        'check all reference documents to find the we need
        Dim oCompDef As AssemblyComponentDefinition
        Set oCompDef = oRefedDoc.ComponentDefinition
        Dim fso As New Scripting.FileSystemObject
        Dim oPartDoc As PartDocument
        Dim oOcc As ComponentOccurrence
        For Each oOcc In oCompDef.Occurrences.AllLeafOccurrences
            If fso.GetBaseName(oOcc.Definition.Document.FullDocumentName) = "TestFile" Then '<------------------------- simplified this name check
                Set oPartDoc = oOcc.Definition.Document
                Set oObjColl1 = oPartDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", "Edge1")
                Set oObjColl2 = oPartDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", "Edge2")
                Call oOcc.CreateGeometryProxy(oObjColl1.Item(1), oObj1)
                Call oOcc.CreateGeometryProxy(oObjColl2.Item(1), oObj2)
                Call CreateGeneralDimension(oActiveSheet, oDrawingView, oObj1, oObj2)
        Next
    ElseIf oRefedDoc.DocumentType = kPartDocumentObject Then
        Set oObjColl1 = oRefedDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", "Edge1")
        Set oObjColl2 = oRefedDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", "Edge2")
        Set oObj1 = oObjColl1.Item(1)
        Set oObj2 = oObjColl2.Item(1)
    Else
        'nothing left to do here
        Exit Sub
End Sub
Private Sub CreateGeneralDimension(ByVal oActiveSheet As Sheet, ByVal oDrawingView As DrawingView, ByVal oObj1 As Object, ByVal oObj2 As Object)
    Set oDrawCurve1 = oDrawingView.DrawingCurves(oObj1).Item(1)
    Set oDrawCurve2 = oDrawingView.DrawingCurves(oObj2).Item(1)
    Dim oIntent1 As GeometryIntent
    Dim oIntent2 As GeometryIntent
    Set oIntent1 = oActiveSheet.CreateGeometryIntent(oDrawCurve1)
    Set oIntent2 = oActiveSheet.CreateGeometryIntent(oDrawCurve2)
    Dim oPlacementPoint As Point2d
    Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oDrawingView.Left + oDrawingView.Width / 2, oDrawingView.Top + 1)
    Dim oGeneralDimension As GeneralDimension
    Set oGeneralDimension = oActiveSheet.DrawingDimensions.GeneralDimensions.AddLinear(oPlacementPoint, oIntent1, oIntent2, kHorizontalDimensionType)
End Sub
R. Krieg
RKW Solutions
