Dim oNewPart vs oNewPart
tomislav.peran
tomislav.peran
I have a question about the variable definition. When using "Dim" in front of a variable name I am not able to use that variable in different blocks (Select Case example).
When I do not use "Dim"  in front of the name I can use the same variable everywhere like in the following example:
Dim oOptions As New List (Of String)
oOptions.Add("1.Choice number 1")
oOptions.Add("2.Choice number 2")
Dim oChosenOption As String = InputListBox("Choose option", oOptions, "", "Railing type", "List of Options")
Select Case oChosenOption ']
Case "1.Choice number 1"
oNewPart = Components.Add(oPartPrefix1 & i, oPartFile1, part_pos, grounded := True)
Case "2.1.Choice number 2"
oNewPart = Components.Add(oPartPrefix2 & j, oPartFile1, part_pos, grounded := True)
End Select
If I used "Dim oNewPart" in place of "oPart" I would get an error when saving.
Can somebody please explain why is that?
Tom
tomislav.peran
And is it maybe possible to define Dim oNewPart As an empty variable and afterward get it inside the block and define it because I can not use variable oNewPart outside of its block?
Frederick_Law
The craziness of VB.
Dim redefine a new variable.
Dim oNewPart create a new reference to oNewPart
Dim oNewPart = create a new reference to oNewPart and assign a value to it.
oNewPart = assign a value to oNewPart using same reference (memory address)
So Dim oNewPart in sub will make it a new variable in the sub with nothing to do with oNewPart outside the sub.
Confess yet?
Curtis_W
Hi @tomislav.peran,
Give this a try.
I hope this helps.
Curtis
Dim oNewPart As ManagedComponentOccurrence
	Case "2.Choice number 2"
End Select
tomislav.peran
God bless you, Curtis. This just might cut my code by a lot.
Thank you for helping on this forum.
Tom
tomislav.peran
Thank you. I will definitely look into it. 🙂
Tom
