Difficulty Placing iFeature Containing two planes and a point
C_Haines_ENG
Message 1 of 1
C_Haines_ENG
I have already developed most of the code, It however just keeps throwing COM errors. Here is the code:
Public Sub Main()
        Dim oPartDoc As PartDocument
        oPartDoc = ThisApplication.ActiveDocument
        Dim oPartDef As PartComponentDefinition
         oPartDef = oPartDoc.ComponentDefinition
		'Dim oSketch As PlanarSketch = oPartDef.Sketches.Item("Placement 2")
		'Dim oPoint As SketchPoint = oSketch.SketchPoints.Item(1)
		'Dim oPlane As WorkPlane = oPartDef.WorkPlanes.Item("Placement 1")
		Dim oFace1 As Face
		Dim oFace2 As Face
		oPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select Select Point")
		oFace1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Face of CAM Connector Hole")
		oFace2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Connecting Plane")
        Dim oFeatures As PartFeatures
         oFeatures = oPartDef.Features
        ' Create an iFeatureDefinition object.
        Dim oiFeatureDef As iFeatureDefinition
        oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\iFeatures\CAM CONNECTOR")
        ' Set the input.
        Dim oInput As iFeatureInput
        For Each oInput In oiFeatureDef.iFeatureInputs
            Select Case oInput.Name
                Case "Point"
				    Dim oPoint1Input As iFeatureEntityInput
                    oPoint1Input = oInput
					oPoint1Input.Entity = oPoint
				Case "Face"
					Dim oPlane1Input As iFeatureWorkPlaneInput
					oPlane1Input = oInput
                    oPlane1Input.PlaneInput = oFace1
				Case "Plane"
					Dim oPlane2Input As iFeatureWorkPlaneInput
					oPlane2Input = oInput
                    oPlane2Input.PlaneInput = oFace2
            End Select
        Next
         'Create the iFeature.
        Dim oiFeature As iFeature
        oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
    End Sub
 It always hooks on either line 41:
 Or Line 45:
 I Thought this might be caused by there being a difference between a iFeatureWORKplane and an iFeatureSKETCHplane but changing that makes no difference.
Does anyone know whats wrong with this? Can iLogic with iFeautres not take more than two of a similar input?
Replies (0)
